Power Steering Bracket Snapped
Hmm. Ok.. it looks bad.
With a replacement bracket, what am I looking at as far as reinstallation?
I mean, I could use the forearm workout turning the wheel without power steering, but I'd like to have it back.
The car is a 1989 944 N/A.
Old 09-14-2010, 11:47 AM
Toofah King Bad
Rasta Monsta's Avatar
You need a new lower balance shaft cover ("gear carrier" in PET). If you have to pay a technician to replace this, it will cost you a fortune.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-14-2010, 12:54 PM
smokin_944's Avatar
Holy crap!! How did you manage that?
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 09-14-2010, 01:24 PM
Toofah King Bad
Easily in a 924S. . .the ps pump hangs way below the bodywork (BTDT).
Old 09-14-2010, 01:25 PM
It happened to my 968 in the same place, I took it apart and a welder I know was able to fix it and add a bit extra to make it stronger.
Many think it is caused by excess vibration from weak motor mounts on miss aligned balance shafts.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 09-14-2010, 01:37 PM
Not sure. But I did have to replace the little tension bar a few times. It kept snapping.
Old 09-15-2010, 08:00 AM
85Porsche944's Avatar
I have had one break from loose bolts on the A/C compressor, and another break from old motor mounts, and yet another from my own over-torqueing. You have to pull everything off the front of the engine to get to it.
Old 09-15-2010, 10:59 AM
that happened to mine too, from the adjuster bolt vidrating loose.
I just used the rear mount and its been fine since.
tks gary
Old 09-15-2010, 03:54 PM
