Dimitri Antoniou
Porsche Crest timing belt
i am 16 and just bought a 1985.5 944 and i need to do a timing belt i have a Haynes Manuel but i still don't really know what im doing, can someone tell me the basics or direct me to the answers.
help!! im 16 and bought a porsche!
Old 11-11-2010, 02:48 PM
pictures
take lots of pictures, make sure they are in focus read...read...and read some more !
Old 11-11-2010, 02:54 PM
smokin_944's Avatar
There is a video by a dude on Rennlist that gives you the procedure to follow. I would go with that as a starting point. He is extremely knowledgeable with 944s.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 11-11-2010, 03:23 PM
meister member
speedracing944's Avatar
Go to Clark's Garage Home Page
click on "Garage Shop Manual"
Click on "Camshaft (Timing) Belt Install, Camshaft (Timing) Belt Removal, Camshaft (Timing) Belt and Balance Shaft Belt Tensioning"
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 11-11-2010, 03:33 PM
Proprietoristicly Refined
John_AZ's Avatar
First, welcome.
2nd, tear out the Haynes procedure on belt tightening. NOBODY USES DRILL BITS TO CHECK THE TENSION!!!
3rd. Follow info above and also read what the supplier of a good tension guage says to do:
Home
Procedure:
http://www.arnnworx.com/tensioningbelts.htm
With his tool:
920X Info
If you do not follow these suggestions you will eventually screw up and ruin the head by bending valves.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-11-2010, 04:28 PM
Why? If your belts are old or if it has been 45K miles since the belts were replaced, then good for you.
If a belt is already broken...you probably have other work to do as well.
Tom
Early '85 944
Old 11-11-2010, 04:39 PM
MDH MDH is offline
Burn the haynes manual...........
And then go to Clarks.
And buy good tools.....
And read at Clarks and these boards....lots of hard earned knowledge!
And have fun with it...........
And whatever you break CAN be fixed......I know this.
And always put some money in the car fund
And dammit have fun
Good luck
1988 924S
It's still cheaper than psychotherapy...................
Old 11-11-2010, 04:59 PM
+1 on Clark's and Arnworks sites.
Porsche Manuals Here: Documents - Porsche 951 - texasblake.com-
for further detail and things not covered elsewhere.
Ask too if anyone here or on Rennlist is near you and might stop by to give advice as a second pair of eyes and ears when assessing a problem or even to coach you through something a bit challenging as you do it for the first time. Or maybe they are doing something you might be able to watch or help with and learn so you know when you turn around to work on yours. I do this to my brother a fair amount.
88 944 na
07 335i
12 Cayman
Old 11-12-2010, 12:15 AM
I found the following three videos most helpful:
YouTube - Porsche 944 Turbo Water Pump Change - part 1.wmv
YouTube - Porsche 944 Turbo Water Pump Change - part 2
YouTube - Porsche 944 turbo Water Pump and Belt change - part 3
I also found the following explanation helpful in setting up the balance shafts:
BalanceShafts
Beyond that, there are articles on clark's garage and arnnworx that will be helpful. I watched the movies all the way through, rerunning parts that I wasn't sure about. He covers everything pretty well, except maybe positioning the balance shafts.
It's pretty much the same operation turbo, or non turbo. 16 valve engines are different, though.
You're going to need a bunch of tools: a crank lock is an absolute must-have, and you'll need a 24mm deep socket to position everything to TDC, and to remove the crank pulley. I found a 34mm deep socket helpful in using the cam gear to adjust tension. A pin wrench is handy for removing the balance shaft pulleys, although there are other tools that would work as well. You can get pretty much everything you need from our hosts at Pelican. The 24mm socket should be no problem buying local. The 34mm socket is also available through any parts store, they're used to remove axle bolts. If you do the fan switch, you'll also need a 30mm wrench or socket.
I did the fan switch, belts, hoses, oil cooler gaskets, and the waterpump at the same time. It required a solid week of work, although the next time through I think the time would be cut in half.
Old 11-12-2010, 05:49 PM
Redline Racer
HondaDustR's Avatar
You don't need a crank locking tool if you are only replacing the belts. The cam belt can be carefully slipped past the rear belt cover near the crank sprocket without having to remove all of that. If you need to replace the water pump, you do have to remove all of that, though. Good luck, look at all of the info above carefully, and ask questions if you get stuck or aren't sure of something. It's not a hard job with the right information.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-13-2010, 11:07 AM
Roman944's Avatar
see if there is someone local to you to help you out with the job
Old 11-13-2010, 03:00 PM
Dimitri Antoniou
because the guy i bought it from doesn't know the last time it was changed so i just don't want to worry about destroying my head or pistons
Old 11-13-2010, 03:02 PM
Mark944na86's Avatar
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Smart move.
Currently 1990 944 S2, Black on Linen, 17" Turbo Twists
Old 11-14-2010, 01:09 AM
Tags
first porsche , timing belt
