flash968's Avatar
looking for rear pic of 951 tach
i need to see the back of a 951 tach - i am specifically looking to see how the boost/vac gauge connects to the car, and if there is a difference in how the rest of it connects versus how the 968 tach connects
basically i want to see if i can use a 951 tach and boost gauge in a supercharged 968, and a shot of the rear is a starting point
Old 12-26-2010, 09:27 AM
That Guy
Techno Duck's Avatar
The boost gauge gets it's signal from the KLR. The gauge is all electronic.
Old 12-26-2010, 09:55 AM
flash968's Avatar
well, depending on the voltage it needs, i could still make it work with a MAP sensor, and in fact, it might even be easier that way
i still need a shot of the rear though, to see what other connections are the same or different
Old 12-26-2010, 11:59 AM
flash968's Avatar
no shots of the rear?
anybody know the voltage range the gauge gets from the KLR?
Old 01-05-2011, 09:03 PM
968 GUY's Avatar
I doubt the accuracy of the factory boost gauge, most rely on aftermarket. I guess if the signal was tweaked or if there is an actual adjustment for the gauge itself it may be more reliable and accurate.
Sorry, but I have fortunately have not had to remove the gauge cluster on the 951...yet, knock on wood...so no pictures. Maybe one of the "dismantlers" can help out.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 01-06-2011, 10:48 AM
