-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   944 wont start! Need help (http://forums.pelicanparts.com/showthread.php?t=603274)
22lambo 04-16-2011 01:46 PM
So my 944 has never had a problem until one morning I try to start it and it just keeps cranking with no sign of starting. Before this problem, whenever I would put the keep in and turn on the ignition I would get a binging noise which would repeat 3 different notes and my gauge lights would light up. No that is wont start, it doesn't play the noise but the lights on the dash are still lit. I put a new DME relay and no luck. What could it be cause it happened out of no where and was driving perfectly the night before. Never had a problem with starting. Any help would be awesome. Thanks
UPDATE:
After more research I am starting to think it's the speed sensor because I checked is there was resistance with an ohm meter but there was no change on the speed sensor. Reference sensor looks good. Also when cranking the RPM gauge doesn't move. So could it be the speed sensor? If so is this link the item I need to buy?
http://www.944online.com/cgi-bin/ASI_Store.cgi?Product+skukey_1195571329+9441+Engin eElectrical-9441
AA_Ezra 04-16-2011 04:08 PM
Try DME Relay
Fuel pump fuse
Post the year of you're car and we might be more help
22lambo 04-16-2011 04:10 PM
Originally Posted by AA_Ezra (Post 5967660)
Try DME Relay
Fuel pump fuse
Put a brand new relay yesterday. Pump is working. The year is 83.
ddbach 04-16-2011 04:15 PM
Here are a couple of No Start checklists to help you analyze this in an organised manner.
Bennington Motorsports
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/484996-let-start-no-start-checklist.html
IIRC some have used less expensive BMW sensors in place of the Porsche ones. I have not had this problem as of yet so hopefully others will confirm this for you along with the correct sensor to substitute. Ah, here's the post:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/457162-my-new-944-reference-sensor-dillema-need-some-advice-porsche-gurus.html
Clark's Garage Home Page
and
Home - Porsche 944 Turbo (951) - texasblake.com
good sources of information and how-to's
John_AZ 04-16-2011 05:50 PM
UPDATE:
944online.com - Engine Electrical Find Parts For Your Porsche 944 And Get Your Car Back On The Road.
22lambo,
Hello & welcome.
To save you money and time...
Clarks garage has a simple resistance check to see if the reference sensor is bad.
Speed and Reference Sensors - Checking, Replacement, and Adjustment
Now, Pelican sells reference sensors. The OEM sensor has a metal silver end at the bottom. I prefer this style to the black plastic in your link.
This is the Pelican Parts forum and we try to support our sponsor.
Now, did you know that there is a 1/2 price interchange for the OEM sensor? The only thing different is the length of the cable.
A BMW 535i years 85-88 will work. Pelican sells these.
Pelican Parts - Product Information: 12-14-1-708-619-M14
Stick with the sensors with the silver end.
More info:
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/609869-bmw-reference-sensor-part-number-need-parts.html#post8187447
Finally, The sensor connections at the rear of the engine get brittle and loose contact. Check and clean the connections.
COVER THE TDC HOLE ON THE BELL HOUSING. DO NOT DROP A BOLT IN THE CLUTCH.
Do not force the sensor out of the sensor bracket. If you damage the sensor or break it off you are in "deep trouble-hours of work".
GL
John
22lambo 04-16-2011 06:50 PM
Wow, thanks everyone for all the help! It means a lot! I have a question about the sensor for the BMW. Could it be possible to get that sensor at stores like Auto Zone or Kragens because I called all of them and of course none of them could get the sensor for the Porsche. Once again, thanks for all the info and now I need to put it to use!
22lambo 04-17-2011 06:59 PM
One more question. Is the reference senor and the speed sensor the exact same sensor or are they different? Cause my local store cant order the BMW reference sensor but they can order the BMW speed sensor
mikepellegrini 04-17-2011 08:20 PM
Yes, the speed and reference sensors on 944's are exactly the same.
I've heard there is an interchange with a BMW sensor (that's easier to find and also cheaoer) but I'm not sure which. And BMW speed and reference sensors may not be exactly the same.
22lambo 04-21-2011 04:06 PM
I just had an epiphany: would a bad reference sensor make the beeping sound when you turn the key to the on position go away? Because I am starting to lean more to the DME. Wouldn't a bad DME do that?
