Which glue for rear view mirror
I accidentally bumped my head against the rear view mirror doing some installation work, and the entire thing fell off. There is a circular trace of glue on the windscreen, and the corresponding surface on the mirror holder is metal. I assume it is all original.
What type of glue should I use to glue this, and are there any special tricks? (Could not find an answer to this when searching through this list, other than that someone saying DIY glueing only lasts for one year?) This is for a 968, but it seems all models use the same mirror. |
Permatex makes a special mirror mounting adhesive, and it needs the special primer with it.
Follow the entire set of instructions.
Good luck, George Beuselinck Last edited by 944 Ecology; 05-02-2011 at 05:07 AM.. |
1987 951
+1 for Permatex. Worked great for mine
Yup, grab the permatex stuff at your FLAPS. Less than 5 bucks....
Hi egil, Go to any local auto parts shop and tell them what you need. Oslo is a beautiful city, at least I thought so when I was there many, many moons ago. Make sure you scrape off the old glue on the glass side of the mirror mount.
Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
You don't need it. Mine fell off a while ago and the bracket that is supposed to hold the mirror disappeared, so I never got around to putting it back up. I wouldn't be surprised if the mirror itself was glued right to the glass though from the PO.
What is good to get the leftover adhesive off the glass?
1984 Porsche 944 1986 Porsche 944 Turbo |
Carefully scrape it off with a new razor blade...
before you scrape off the old glue take a crayon and mark the glue location on the outside of the windshield so you will get the mirror back in the same spot. Amazing how hard it is to get back right without doing this.
BTW, the guy at the Porsche dealer recommended tape, which I think is not good advice. So no luck in locating Permatex glue, and even Loctite (guys I trust) was hard to find. So I had to resort to something called Granville (made in UK?). There was no accelerator. The package said the glue would harden in a minute, but I think it must have taken much more than an hour (I held the metal plate in place with tape while it was setting). Anyway, the next day it did seem like the glue had hardened, and it has held the mirror in place so far. |
