uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
Question Handbrake sensor?
My handbrake light will come on briefly when I turn the car on and use to stay lit on the dashboard until I released the handbrake and fully lowered it. Now it turns off as soon as I touch the release button or slightly release it. Every time I take the car to the car wash, the idiots move or drive the car with the parking brake engaged because the light doesn't remain lit on the dash. Where is the handbrake sensor located and how do I replace it?
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 05-23-2011, 07:12 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
It's a button mounted right under the lever. Raise the lever and look at the front end of the bracket, you'll see the black button sticking up.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 05-23-2011, 07:20 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
+1^ Also the replacement parts are basically the same as the door open/interior over head light switch that is in the front of the door jam.
Basically the emergency brake light switch sits under the hand brake lever and when contact is made with the hand lever being down it breaks the electrical circuit and the warning light goes out - it is adjustable...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-24-2011, 08:36 AM
vdubr928's Avatar
Its also easily repaired. They don't get much simpler. You may have an open short in the wire though. The light always comes on for a second when you turn the car on. This is the ccm's way of showing you the bulb is good. When you are stopped, engine running, and you set the brake....... does the light come on then? If not then for some reason the circut is never being grounded. You will probably find that the wire is seperated from the button. Little dab of well placed soulder should correct. Use rosin core.
Or go to the junk yard and pick up another. I probably have 6-7 of them if you are unable to find one ill drop one in the mail for you. Pm me if you can't fix yours and can't get local. Should go on a snail mail stamp.
82 928 s3&1/2 5 Speed LSD conversion
87 944 N/A 5 Speed (Under Construction)
81 931 (maybe for sale, well their all for sale lol)
Always looking for a good deal. Hello, my name is Carl and im a Poschaholic
Old 05-24-2011, 10:24 AM
uvachief
uvachief's Avatar
Thanks! The light doesn't come on after initial start up. I replaced the long emergency brake cable last year and I bet I disconnected the wire or knocked it loose pulling out the old stuck cable. I will check.
Sincerely,
uvachief
Old 05-25-2011, 07:11 AM
uvachief
uvachief's Avatar
The wire had come loose. Plus the bulb in the instrument panel was on its last legs. Works fine now. However, the "!" no longer comes on when the emergency break is engaged. The green light with the words does in the temp/fuel combo guage. The "!" use to come on when it was engaged but the green words didn't light up. I thought both were supposed to come on? Can't figure out why the "!" only comes on at start up.
Sincerely,
uvachief
Old 08-11-2011, 11:46 AM
Tags
dashboard , handbrake , light , sensor
