Found a frwilk Chiped DME, how to install
OK so im pretty excited right now. Its an early dme With the dual chip adaptor board and already has the toggle switched installed so its good to go.
Question is will it just be a plug and play? the page on his site is gone so I don't have instructions for the instalation. Do i have to jumper the altitude sensor? or is that just for late cars. anybody know of another connection in the vehicle that i could cutt off a junk car to make a jumper?
I just want to install it already, but i want to do it right
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 08-05-2011, 12:49 PM
i think is plug and play because altitude sensor works on very high altitude difference....
please when you put it and drive it send me you opinion(if you don't want to forum it give me a messege)
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 08-05-2011, 01:10 PM
RIchard944's Avatar
It is the same as your 83 DME, physically. It is just the memory chip that has changed and the programming inside.
or you can contact them at
frwilk@PowerPROM.com
1989 Porsche 911 Carrera
1984 Porsche 944 (with PowerProm & dual chip adapter)
Old 08-05-2011, 01:19 PM
If it is the dme with performance mode and toggle for regular mode just make sure that you don't switch the toggle when the car is running. It does not like that and will shut down and you will have to let the car sit for a short while before it will fire up again. I installed this in my 83 and liked it very much.
Old 08-05-2011, 02:17 PM
Yes it has the toggle, I was going to crak itvopen again and post pics, I opened it at the junk yard to check. It does have a toggle. Ibwas thinking of turning car off in between switching modes. How do I know which mode I am in?
Going to open it and clean it up a bit
Old 08-05-2011, 02:50 PM
If there is no tag on the dme itself. I would just try it one way and see if the car acts the same as your stock dme acts or if you feel a small amount of extra pep out of that motor. You will know for sure then.
Old 08-05-2011, 03:10 PM
Surely you'll be able to tell which mode you're in. If you can't, I'd say it isn't really an upgrade!
1986 924S, Maraschino Red, Spax adjustable dampers, no air box lid. part way through interior swap. Lots of issues sorted, plenty more to do.
1986 924S, White, donor car, part way through disassembly.
Old 08-05-2011, 03:16 PM
Old 08-05-2011, 03:21 PM
Pictures to be posted soon, there was writing with a white pen on the outside I'll let u guys decipher it but from what I gather it's an 85 early dme with 6k rpm limit
Old 08-05-2011, 03:46 PM
RIchard944's Avatar
6500 or 7000. There were only two versions
Old 08-05-2011, 04:03 PM
unindicted co-conspirator
looneybin's Avatar
if it has a toggle, then you probably don't need to jumper the high altitude sensor.
The jumper is to fool the DME into switching to the high altitude fuel map, which has been replaced with the FRWilk chip
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 08-05-2011, 04:39 PM
That woudl be cool. had to run back to the junk yard came back. and empty light turned on. put 1 gallon of gas 91 and going to install now and then go fill her up.
Jaime O.
Old 08-05-2011, 05:56 PM
ok here's the eye candy pictures
Jaime O.
Old 08-05-2011, 05:58 PM
RIchard944's Avatar
You can read the serial number, SN120. If you send that to FR, he can probably tell you all the specs on it. This is off a wrecked car?
On mine, switch forward toward the engine is the performance chip.
Old 08-05-2011, 06:13 PM
Yup off a wrecked car an auto on top of that. No physical damage tbelts were intact front sway bar was bent upwards to the frame maybe while the forklift moved it. And the rear passengers side stub axle had crazy among of play.
I honk I figured out the switch just put the dme in and recede the engine, turned off flicked the switch and recede it again it seemed quicker now I'm going to test drive
Old 08-05-2011, 06:39 PM
Ok back from the drive, didn't really notice a difference honestly. Maybe one does need to jumper the altitude sensor, I do have a lightened flywheel and that pretty much eliminated the dead spots I had before. Half a tank of 91 too. I think the idle is higher once I push the switch tirades the engine. *sigh*
Old 08-05-2011, 07:27 PM
looneybin's Avatar
i didn't notice any more power, it just moved the torque curve around, in that the dead spot between 2,500 & 3,000 RPM is gone
Old 08-08-2011, 08:38 AM
