2.7 and 2.5 injector flow rates
Had a a browse around and read thru my cheap reading specs that the flow rate for the 2.7 is less than that of the 2.5 injector,sounds backwards to me.
Can anyone confirm?,I'am asking because I 'am running a 2.5 fuel rail and injectors on my 2.7 because I had a leak @ my 2.7 rail. Could I be running lean?new plugs look ok,thanks
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
how does it run?
1988 944 turbo |
Idle is a little unsettled but otherwise ok,is the latter fuel rail a better design?,if not I may just go back the the 2.7 injectors in the early rail.
