Found that the oil pressure warning wire was loose at the sender. The tiney threaded brass stud had broken. Soldered the connector directly to where the dud used to be! Took a bug soldering iron and some Yoga. Next time I will put it up on ramps first.
Auto correct is killing me. It was definitely a stud and a big soldering iron.
glad you clarified that Tom. For a moment I thought I was going to have to do some research on some terms I havent heard before. I was pretty sure Clarks Garage never mentioned soldering bugs to studs
Black 1984 944 2003 Land Rover Freelander SE3 |
Andrew Gawers' Dad
Painted my phone dials satin black with VHT wheel paint.
AFM #725
Looks awesome dude!
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Andrew Gawers' Dad
Thanks, I need to get them rebalanced, and I'll take more pictures. The VHT paint was real easy to work with btw.
AFM #725
I was considering re-painting mine satin black, but I'm going to see how the polished aluminum looks first after stripping the red off. Whenever I get to that. Life is just too busy...
Very nice! I've been thinking of doing something similar.
Can you outline the process required? What sort of prep is required, etc.? Thank you for anything you can pass along!
'95 993 C2 - Guards Red, Black - 6-speed, sunroof, power seats, not much extra '08 Cayman S - Meteor Gray, Cocoa '90 944 S2 - Gone, but never forgotten I love these cars!!! |
Andrew Gawers' Dad
Cost was $28 for three cans of VHT satin black wheel paint, and a Bondo spray paint gun. Three cans worked, but four would have probably been better. Paint was bought from Autozone.
Prep: Removed wheel weights, and used 3m adhesive remover to remove the sticky stuff left from the wheel weights, and wheel weights past. Used Simple Green, and a red scotch bright pad to clean the rims. Left to dry over night. Paint: Gave rims a quick wipe down with alcohol. Taped valve stem cap, and tires best I could. No primer, two light coats, and one medium coat, all 10min apart. VHT has really good instructions on the can. Here's a pic of the can:
AFM #725
Why no VHT primer?
Andrew Gawers' Dad
VHT says primer is not needed, unless you're painting over bare metal. We'll see how it holds up, but either way, I just wanted to see how satin black looks vs the oem silver because I plan on having the rims refinished soon anyways.
They look great. I am thinking of repainting mine the original color. Currently the silver is wearing off and they are looking slightly gold!
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Replaced the Air intake hose, changed oil and washed/waxed car.
Guy '87 944 (first porsche/project car) |
Had it inspected... passed with no issues...
Those of you ive seen on here with strut tower braces, where did you get them? Seen any powder coated?
Chris from NC ------------------- 86 944 covid19 Project 90 944 S2 Cab - triple black 66 mustang Last edited by State2Cab; 11-07-2012 at 11:20 AM.. |
Andrew Gawers' Dad
I got mine from KLA, and it comes zinc coated to match the other zinc coatings under the hood. Never seen one powder coated.
Andrew Gawers' Dad
Got her washed, and the tires balanced, then went on a drive.
^ The wheels look great! I'm thinking either satin black or a smoked chrome for mine.
Andrew Gawers' Dad
AFM #725
Plastidip them lol
