AFM #725
Price check for Sway Bars
How much would be a good price for a pair of used 944 turbo front and rear sway bars? $200? Or less?
Also, since my 944 didn't come with rear sway bars factory, how difficult would it be to add the rear?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Adding a bar to the rear of a 944 is a piece of cake. Just make sure you get the bushings, drop links and brackets.
$200 for everything would be an okay price. $150 would be a good price. $100 would be a good price if you only get the bars and nothing else. |
AFM #725
I have new bushings for the front sway bar I never put on my old 944. I don't have rear bushings, or drop links or brackets. Not sure exactly how that goes together. One of the guys at Parts Heaven told me you usually need to replace the inner sway bar bushings, those are the ones that go bad. Looking at both my 83 and my 86 that seems to hold true, on both cars the inner ones were heavily cracked and falling apart while the outer were looking old but more or less okay condition.
I will have 968 factory bars available in 2 weeks, once i have M030 bars installed.
Bushings should still be fine, but i will inspect after being removed. Might be best to have fresh bushings. If interested let me know. FQ |
Hopefully your 86 has the same sized sway bar as the 83 did. Otherwise that would render the inner bushings useless.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
AFM #725
968 vs 951 sway bar? And good point. I had just assumed they were the same.
i still have a set of 968 sway bars, complete with bushings in excellent shape, that all came off a car with 22k on it
the link has a bad number on it, and the front bar is 26.8, but the link works http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/679549-swaybars-sale-25-5mm-16mm.html |
AFM #725
You never sold the ones in that post? I'm interested.
AFM #725
What do you mean by a "bad number"? Would you have all the hardware I'd need to mount on my late 944?
no, i never sold them
the link says 25.5, but it's really a 26.8. if you have bars front and rear now, then you should need no new hardware |
AFM #725
I have front. No rear. Just a torsion bar.
then you will need the rear brackets and drop links
AFM #725
Would ones from an S2 work?
from what everybody says, yes. it seems the bars and hardware all interchange across the later cars
they do. my '86 only had a 20mm front bar.
i got a 26.8 from an S2, a 18mm rear from a turbo, drop links and brackets from DC auto and paragon.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels Last edited by J1NX3D; 08-24-2012 at 05:07 PM.. |
