AFM #725
Gawernator's Avatar
Rear sway bar commonality
So, today I realized I do indeed have rear sway bars. Silly of me but since the option code wasn't on the sticker I just assumed the car didn't have it. My '83 didn't either. How common was the rear sway bar for the NA's? What difference does the rear bar make?
Old 09-01-2012, 07:44 PM
9FF 9FF is offline
9FF's Avatar
Sway bars control body roll in turns. Rear has the same effect as front in controlling roll. Impossible to say which years did or did not have rear sway bars except 88+ all had them, before that many did, some didn't. I think US models all had them 85.5 on.
Old 09-01-2012, 08:16 PM
My 84 had the M456 option which is Koni's and a 23mm bar on the front and an 14mm bar on the rear. It was so awesome. My S2 obviously had the rear bar but it also had the huge front bar so it was a bit more prone to understeer then if you lifted in a corner the rear would come around.
Old 09-01-2012, 08:39 PM
AFM #725
Gawernator's Avatar
That article says the 944 came with variable assist power steering? I have not noticed that feature in my PS
Old 09-01-2012, 09:21 PM
That Guy
Techno Duck's Avatar
Its just a fancy way of saying power steering was optional on the '83 models. Variable assist basically just means less pump assist at higher engine speeds.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-01-2012, 09:25 PM
AFM #725
Gawernator's Avatar
I mean I do understand the technology, my dad's 911 has the same. On my 944 it's just only slightly difficult at low speed and not hard at high speed lol. Instead of very easy at low speed and regular resistance at speed. Like my pump isn't changing it's pressure really. Idk
Old 09-01-2012, 09:48 PM
9FF 9FF is offline
9FF's Avatar
I snapped that pic from the original 1998 Peter Morgan book. What it doesn't say and what we all now know is that a depowered ps rack works quite well as a manual rack. The reason being that the ps rack has a lower ratio than the manual rack and when combined with the later ps smaller steering wheel, it's a wash on the ratio with the manual, plus you get better leg room.
Also what it doesn't say is that there was a "sports" manual rack option for the 944 that has a quicker ratio closer to the ps rack part# 944 347 015 00 It was developed for the early offset turbo cup cars but was offered as a "sports" option on all the models.
Old 09-02-2012, 04:41 AM
Misunderstood User
PS on 83's are very rare. Rear sway bar for 83 was an option.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 09-02-2012, 07:09 AM
Volhv's Avatar
Here's a picture of my manual rack with that part number.
Sand blasted,
and painted.
So does this mean the steering will be heavier than if it were part# 944 347 011 00? Oddly enough the only other manual rack I have worked on had the same part number as mine.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 09-02-2012, 11:17 PM
9FF 9FF is offline
9FF's Avatar
"So does this mean the steering will be heavier than if it were part# 944 347 011 00?"
Yes, a little heavier but then all the manual racks for our cars are tough on the biceps at low speed, parking, u-turns, etc.
Old 09-03-2012, 02:13 AM
Volhv's Avatar
Thanks for the info. Haven't swapped it in yet. I will wait for the power rack to start leaking before I do that.
Old 09-03-2012, 10:41 PM
