84 944
glass water stains
Does anyone know how to get rid of water stains off the windows? I've got some serious water stains on my passenger window and rear deck glass. A bunch of timy dots, looks like rain or something. I've tried 409, Invisble Glass cleaner even a razor blade and none of them worked.
When I had old paint overspray on the windows from the previous owner, I used carb cleaner sprayed on a rag, and then windex, it wiped right off.
I saw this company's products on one of the Saturday morning car shows on Speed several years ago. I tried it before a big car show and was impressed with it's effectiveness. I am generally not really a Concours person but Porsche was the featured marque and I had nagged others into participating so I had no way out.
Welcome to Diamondite® The Ultimate Glass and Plastic Care Systems.
88 944 na 07 335i 12 Cayman |
Toothpaste.
84 944
84 944
84 944
And do you think that stuff would work on my rear wing? Its looking like crap, faded and crackly looking. Last edited by nutless_neo; 11-18-2012 at 12:37 AM.. |
Decal is available right here from Pelican Parts
For the rear wing/spoiler I've tried both Back to Black and the inexpensive Vaseline treatment. Both work well although my impression was the vaseline seemed to last longer but took a bit more effort wiping it off. YMMV I wouldn't use glass cleaner for the wing. Oh, the test for clean glass? Put a plastic baggie on your hand and run it over the glass, you'll feel the dirt you don't see. After using the Diamondite product totally smooth. Hvae you tried claying the glass?
88 944 na 07 335i 12 Cayman Last edited by ddbach; 11-18-2012 at 04:05 AM.. |
Yes toothpaste seriously. It is mildly abrasive. Used it on an old square back I restored. Plus it leaves your car minty fresh
I was at an auto glass repair shop and noticed a product for hard water stains,although I can't remember the name. Maybe there is a shop locally you can check.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
84 944
Well I tried the carb cleaner and that didn't work. I even tried Goof Off and nothing. I will try the toothpaste trick in the morning, who doesn't want a minty fresh car?
I used a tire cleaner on my rear wing and that helped a lot, especially getting all that dirt off but eventually I will need a new one because its pitted with small holes. Thanks for all the replies and advice!
I use Bar Keepers Friend, it works well for me.
AJ
89 944 Turbo Guru Chip Lindsey Boost Enhancer 3bar Reg. |
This is not the first time I have had someone say toothpaste, I will give it a try when I have some time.
86NA944 |
Incorrigible
Vinegar will dissolve hard water deposits - just keep it off your paint and rinse afterward. It is really just a mild acid that dissolves the calcium deposits left when the water evaporates.
Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
the best method is to use "0000" super fine steel wool..it's amazing..then give a nice coat of rain-x..does not leave any scratches and you'll be amazed that you didn't do this before...hardly takes any pressure going over it and your glass will be "smooth as glass"..done this to all my cars and the super fine steel wool..(0000)-grade is about $5...warning..do not use anything but "0000"super fine steel wool pads---haven't ever used anything else ...also takes off paint overspray and bird sap and any other crap that's on glass
Beer Cigars and a 10mm socket... |
86NA944 |
Here's where I found this...IT IS ABSOLUTELY AMAZING !!!!!!!!! DO NOT SPEND ANY MONEY ON THOSE SO CALLED POLISHES....or toothpaste..are you kidding..what a mess..
HOW TO: Super Clean Your Windshield - YouTube
AFM #725
I might need to try that on some marks on my rear hatch glass (I have a one year old windshield
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Watched it.
Did it. Looks great. Quote:
86NA944 |
84 944
Well, Ive tried all the suggestions, including the toothpaste with a scour pad even and nothing worked. UGH! Any other ideas?
