BTERRY1's Avatar
it was a joke Joakim. there has already been some really good advise given. it is not like i was the only one responding. Even Toran the original poster found humor in it.
Old 11-27-2012, 09:21 AM
I realize that it was a joke as mine was too.. as I stated with the curry
white 81 924
Old 11-27-2012, 09:24 AM
BTERRY1's Avatar
Old 11-27-2012, 01:24 PM
Toran's Avatar
Picked up a few Desiccant Bags.
Will try the RTV silicone gasket maker once it gets a little warmer(that stuff doesn't like to come out of the tube in cold weather)
Seriously going to have some friend rice with curry, and will report back on the success.
Thanks again!
86 944na Alive and Rollin
Old 11-27-2012, 02:14 PM
AFM #725
Gawernator's Avatar
I was just going to mention the silica bags, lol. Why not get a dehumidifier and plug it into the DC outlet
Old 11-27-2012, 02:16 PM
Toran's Avatar
She's an outdoor car for now and hooking up a dehumidifier via a DC outlet would be pain.
I even looked online for a small dehumidifier that would run from the cigarette lighter power source but no such luck at the moment.
California guys dont have to worry about interior frost/ice on windows!
Old 11-27-2012, 02:25 PM
AFM #725
Gawernator's Avatar
Sometimes in January/December I could get frost but it doesn't get much below freezing
Old 11-27-2012, 02:46 PM
How many silica bags did you intend to put to your car?
I had one in my car, it was about smaller than my fist and it did its job almoust... it was a soaking wet too as the carpet
I would recommend the heater because it is fast and direct heat.. I used it to blow the heat directly to the wet carpet so the heat will vaporize the water and moisture..
I had to use it for four weeks because it taked that long to get the hole carpet to dry..
and when I putted it to blow directly to wet carpet, I could see the mist forming to sideglasses in about 5 to 10 minutes
Thats why I opened the tailgate.
Btw. I used ac heater..
Edit: remember to leave good gap between the carpet and the heater and support the heater too!!!
Or it could burn your carpet or your hole car
white 81 924
Old 11-28-2012, 12:27 AM
Toran's Avatar
I ordered four small Desiccant Bags.
Will put one on the driver's side dash and will have to see about the remaining three.
Thank you for sharing your input and experience.
Old 11-28-2012, 04:50 AM
I think my only problems with my 924 in winter is that the cockpit is not getting warm enough to drive far, but the problems could be missing bottom motor shield..
and that the motor can't handle any hitting the gas pedal on first 2 or 3 start ups.. I think that the motor gets too much air and thats why dies... but after the third start I can hit the gas as I like, only minor glitch is that the perhaps 1 cylinder is not starting properly and the car is taking rpms like a two stroke engine about 10 to 15 seconds when pumping the gas pedal.. and then the motor runs correctly.
that cylinder idea is only a guess
white 81 924
Old 11-29-2012, 02:29 PM
