hard start when temp is below 40 F
Car starts fine excepts when it gets real cold. Its been doing this the last few yrs and since i havent been driving it in cold weather i never fixed it. Now i want it fixed!. Car is 86 turbo.....i replaced fuel filter, and fuel pump check valve.. but i haven't ever replaced plugs in 15K miles since i've owned it over 5 yrs. Any other suggestions
Possibly the DME temp sensor. Like a $20 part, get the Bosch. Easy to install and remove. It senses when the engine is cold and enriches the fuel mixture until it warms up.
Move to a warmer climate? Sorry, I just couldn't keep from saying that
It started up right away after sitting outside that night, yikes, sorry car. Never has failed me, so far.
What oil are ya running, 20w50?
I'll assume that was towards OP, however I run 20w50 and have no start issues, coldest I've started is 36 degrees now. According to the owner's manual, porsche says 20w50 can be used down to around 10-15 degrees F
This check valve? 944-608-951-01-M14 Pelican Parts - Product Information: 944-608-951-01-M14
As for the temp sensor, referencing this thread: http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/184320-temp-sensor-dme.html Would appear that this: http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=944-606-125-00-M14&catalog_description=DME%20Temperature%20Sensor %20%2820C%202%20Pin%2C%20Blue%29%2C%20924S%2F944%2 F968%20All%20%2802%2F85-89%29%2C%20Each%20 Is indeed the correct sensor. Idk why PP has it listed as 85/2+ |
i had same problem ...i fixed mine by replacing the rubber hoses the go to the idle control valve .....they were dry rotted and cracked
When it's cold in the morning I'm hard to start up, but I'm old as dirt. It'll be 27* in the morning.
Cheers, Larry |
thanks i'm gonna try new temp senserSmileWavy
I must still be a new engine
| All times are GMT -8. The time now is 03:58 AM. |
