cro-cro's Avatar
Question 944 Transmission Mounts?
About every other shift, depending on how smoothly I release the clutch or let off the gas pedal or press the pedal I hear a clunk coming from the back. I asked a friend about it and he said something about the transmission mounts. I'm new to a lot of things with this car, but he said if the mounts are warn it could be hitting the body of the car. Is this a common issue and am I using the right terminology? Any suggestions on what to do about the clunk in the trunk?
Thanks!
-Drew
Old 05-17-2013, 11:37 AM
Proprietoristicly Refined
John_AZ's Avatar
Some members have had success by filling the transaxle mount with poly:
Basic DIY info:
Homemade Motor Mounts
I would check your CV bolts for tightness first.
Depending on the car mileage you may also try to swap the Left axle (mark inside/outside) to the Right side (mark inside/outside). This moves the bearings to another path on the CV.
If the clunk persists----it may be a wheel bearing.
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-17-2013, 11:51 AM
thekidd's Avatar
Send a message via AIM to thekidd
Clunking may be the clutch, if there is slight "bucking". My car did this for 4 years. 2 years ago a shop said the clunking I heard and felt was the clutch on its way out. A little over a year later my rubber centred clutch finally gave way. 205K miles later ( bought with broken odometer)
Old 05-17-2013, 05:06 PM
Hi Drew, It helps to have the year of your 944 down in the signature block. A good DIY MOD for filling the trans mount with urethane to firm it up is at the link below.
Any DIY for the transmission mount? - Rennlist Discussion Forums
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 05-17-2013, 09:58 PM
Redline Racer
HondaDustR's Avatar
+1 on the urethane mounts. I used window weld windshield adhesive and they have been just fine.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 05-18-2013, 12:39 AM
Tags
944 , noises , transmission
