Mike_944's Avatar
Need to replace water pump...what else?
While I'm in there what else should I replace??
Any good sites for parts?
Old 07-23-2013, 04:00 PM
mhariush's Avatar
Why are you changing the water pump? You have to undo the timing belt so might as well do a timing belt change if you haven't done it recently. And you might as well change all the front seals too while you're at it. And you're changing the thermostat too I guess?
This site (Pelican Parts) is pretty good for parts... just click the "New Parts Catalog" up top
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 07-23-2013, 04:28 PM
Proprietoristicly Refined
John_AZ's Avatar
Mike,
Pelican?
Begin with the waterpump , new or quality rebuilt, none of the cheap ebay China crap.
FOES-Front Of Engine Seals --- Pelican sells a kit.
New belt rollers and belts.
Clean the cooling system and radiator-do not use a full bottle of HD Prestone flush or similiar. Use half strength.
Test for coolant leaks before you remove the WP with a pressure tester to find pinhole leaks. 10 pounds pressure max.
New heater control valve and hoses
New thermostat and fan relay. Antifreeze.
Anything you break along the way...
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 07-23-2013, 04:32 PM
John_AZ's Avatar
and....
WP bolt installation kit
If your WP bolts are rusted, be prepared to drill out if one snaps off. A right angle drill attachment may work.
You may also need to replace the block threads.
Block off plate "O" ring
If the WP comes with the "Green" seal ----no sealant is required. It is on the gasket already.
If the WP comes with the black seal-- use a sealant like Permatex Hylomar or ...
J_AZ
Old 07-24-2013, 06:29 AM
Andrew Gawers' Dad
CHICKS's Avatar
Buy from Zims, much better prices, and better customer service.
Old 07-24-2013, 11:03 AM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Porsche Crest
J_AZ
and....
J_AZ
Recommended for PelicanWiki... Good on ya mate.
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 07-24-2013, 12:37 PM
Paul_Heery's Avatar
Anything you break along the way...J_AZ
Truer words were never written
Old 07-24-2013, 01:08 PM
Mike_944's Avatar
Thanks everyone for the responses!!
I was hoping to fix my new 944 but this one needs to come first as it's my daily.
Old 07-24-2013, 03:59 PM
