Need to replace water pump...what else?
While I'm in there what else should I replace??
Any good sites for parts? |
Why are you changing the water pump? You have to undo the timing belt so might as well do a timing belt change if you haven't done it recently. And you might as well change all the front seals too while you're at it. And you're changing the thermostat too I guess?
This site (Pelican Parts) is pretty good for parts... just click the "New Parts Catalog" up top
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush http://stores.ebay.com/Techniker-Parts/ |
Proprietoristicly Refined
Mike,
Pelican? Begin with the waterpump , new or quality rebuilt, none of the cheap ebay China crap. FOES-Front Of Engine Seals --- Pelican sells a kit. New belt rollers and belts. Clean the cooling system and radiator-do not use a full bottle of HD Prestone flush or similiar. Use half strength. Test for coolant leaks before you remove the WP with a pressure tester to find pinhole leaks. 10 pounds pressure max. New heater control valve and hoses New thermostat and fan relay. Antifreeze. Anything you break along the way... J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
and....
WP bolt installation kit ![]() If your WP bolts are rusted, be prepared to drill out if one snaps off. A right angle drill attachment may work. You may also need to replace the block threads. Block off plate "O" ring If the WP comes with the "Green" seal ----no sealant is required. It is on the gasket already. If the WP comes with the black seal-- use a sealant like Permatex Hylomar or ... ![]() J_AZ
Andrew Gawers' Dad
Buy from Zims, much better prices, and better customer service.
1988 944 2.5L 8-v NA 301k
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
Thanks everyone for the responses!!
I was hoping to fix my new 944 but this one needs to come first as it's my daily. |
