shift linkage removal
I cannot find in the shop manual where the shift linkage is removed. I cannot gather from my previous post how to do this. I think the torque values are in the SM. I am aware of the after-market shift linkages available.
I want to remove it to put a seal where the shaft goes into the transmission. are there directions in the SM? is this a matter of simply undoing the nut on the "connecting rod"-like piece, slipping a seal over the shaft, and using the same nut to tighten? pic: ![]() previous postings: http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/778637-tranny-parts-articulated-arm-shift-link.html http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/780117-transmission-bracket-trouble.html
87 944 NA Last edited by Bukowski; 11-07-2013 at 07:33 AM.. |
944 addict
Yes, undo the nut, pry the shift lever off the shaft (expect the shaft to move in and out), use a little emery cloth on the possible burrs, re-do the seal and then push the shift lever back on and replace the nut with some locktite red on the threads. By the way, this is a good time to install the short shifter from only944.com. You won't regret it and it's so cool!
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
I might have been asking the wrong questions -
the seal I want to replace is around the shaft that the shift lever is tightened onto. The seal is inside the transmission case, but is visible. The SM describes prying this seal out. I need to know about the shaft - the one that the lever rotates. It is not clear from the PET how this shaft is held in place other than the shift lever. I looked at the only944 instructions, still wasn't clear. so another way to ask is, when the lever comes off, how is the shaft held into the transmission?
87 944 NA |
You take that selector shaft out from the other side of the transmission. I believe there is a flat triangular aluminum cover that is held by hex head bolts.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
UPDATE: while I am working this out - I could be wrong, but the seal I am interested appears to be the subject of this tutorial: http://www.pelicanparts.com/techarticles/mult_shifter_rod_seal/mult_shifter_rod_seal.htm that's for 356 or 911, but Dempsey claims it is similar for other Porsches. Also I already have the exact tool he describes to do it - one less tool to get... so for "non-hardening gasket sealer", would one of the Permatex "form-a-gasket" non-hardening sealers be adequate? so nothing too specific, just a general product? also another question assuming that tutorial is useful for 944's : when the shift lever slides off the shift selector rod, it has to make an angle - how much of an angle is there? how cautious should one be with this - is this potentially damaging the rod?
87 944 NA Last edited by Bukowski; 11-08-2013 at 02:39 PM.. Reason: found link |
how is this going to work - when that plate comes off, is the shaft going to spring out? should the opposite side be loosened first?
87 944 NA |
AFM #725
This is what you're trying to do right? I removed and installed in 30 minutes tops Short Shifter Instructions - only944.com
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
how does the shift rod go back in - just push it in and it will find its way? I am considering just doing the shift rod seal instead of that opposing seal under the cover.
87 944 NA |
The shift rod has a spring behind the cover. It pulls out from that side. Once the rod is out, you can pull out the rod seal and change it. You may try to change it without pulling the shift rod. You can probably put a metal screw to it and pull it off the housing. That rod seal is high up above the case and they do not usually leak gear oil. Is it really leaking gear oil?
the paper gasket for the triangular piece - will a piece of oil-resistant stuff from the FLAPS be adequate or am I going to have to wait for the Genuine Porsche piece to come in?
87 944 NA |
AFM #725
I've never heard of that leaking... I don't think I even knew there /was/ a gasket there!
