Wont turn over
Would any of you guys happen to know what voltage I should be reading at solenoid trigger wire on starter when key is turned? I'm getting a reading of 10.58v
!2.59v at battery… Normal?
Thanks, Mike
Old 05-20-2014, 06:16 AM
I forgot to mention it's on an 86 1/2 944
Old 05-20-2014, 10:46 AM
It should read the battery voltage. Check your wiring and your ignition switch.
Good luck, George Beuselinck
Old 05-20-2014, 11:47 AM
Straight shooter
Lapkritis's Avatar
Check for an aftermarket alarm or splicing on the steering column harness. Any butt connectors will cause an increase in resistance and a voltage drop. If you find any splices on the wire to the ignition switch, get a soldering iron and shrink tube for proper fix.
Are you measuring the voltage with the wire disconnected from the starter or while cranking and connected to the solenoid?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 05-20-2014, 12:38 PM
Checked while key is turned and connected to solenoid… It doesn't turn over just one click. I thought that I read a long while back that it isn't supposed to be 12 volts… More like 8 or 10 point something. But I can't find where I read that.
Old 05-20-2014, 05:05 PM
