horsman_f3's Avatar
Send a message via Yahoo to horsman_f3
Engine noise
It seems like I have more exhaust noise in the engine bay, and a slight decrease in power at times(which I think is my fuel pump). But when I open my hood and have a listen, there seems to be more of an exhaust noise coming from the engine. What would be some things that would cause that??
Old 08-07-2014, 05:00 AM
tamathumper's Avatar
Loose or broken exhaust header studs or flange bolts.
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 08-07-2014, 06:03 AM
Proprietoristicly Refined
John_AZ's Avatar
Cracked exhaust header 1-4.
Look up from under car where the 2 pipes join for cracks.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-07-2014, 07:00 AM
Bradical's Avatar
The first thing I would check would be the o2 sensor, it's fairly common for them to be cross-threaded, which causes them to rattle loose over time. It sounds like a nasty header leak.
Old 08-07-2014, 07:37 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Put a piece of Kleenex on the end of a stick and move it around the exhaust system and manifold. Look for the Kleenex to flutter in the area of a leak, while the engine is running. I saw this cool trick on Wheeler Dealers. It actually works.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-07-2014, 08:05 AM
horsman_f3's Avatar
Thanks for the tips!!
Old 08-07-2014, 04:41 PM
Toran's Avatar
Do let us know what your results are.
I am in learning mode
86 944na Alive and Rollin
Old 08-08-2014, 05:41 AM
