suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
Power steering and devine intervention
can anyone explain why my powersteering has suddenly stopped leaking?..Car handles beautifull, and yes the pump ios working also. Maybe the seals have just ....er.. resealed?.. Todwic?.. anyinfo from you is well worth a look.. eh?...
may the schwartz be wit chew,
Frank B
ps.. rent the movie strange brew.. it's hockey seson.
Old 10-22-2002, 11:43 AM
SoCal Driver's Avatar
The reservoir is empty.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-22-2002, 12:16 PM
suck my tail pipe
Frank B's Avatar
it's full Socal, weird huh?.. radiator has a small leak, need a new one.. dang!.. but the P.S. is workin just fine now, even when I crank all the way left or right....
thanks Socal,........
Old 10-22-2002, 12:21 PM
Bored. Trying to be funny... Yawn...
Most cooling leaks around the radiator are loose or cracked hoses. Every so often the plastic sides crack or start leaking at the seal. Then there are a couple of plastic fittings that screw into the plastic that leak. These you have to be really careful with not to over tighten. Lots of teflon tape.
Back to the hoses. If you have "mud" in the overflow tank there is oil in the coolant. This oil can ruin the hoses. I've also seen the hose fitting on top of the engine deteriorate because of the absence of antifreeze. Doesn't leave much for the hose to clamp to.
Old 10-22-2002, 12:30 PM
suck my tail pipe
Frank B's Avatar
yeah, plastic at the bottom has a teency weency crack, but it's not bad.....thanks SoCal. Why does this car feel like it's more comfortable at 60-100mph than 10-35 mph..?.. any help?......
Old 10-22-2002, 01:20 PM
Because it's a 944!!!!!!
A blend of the best technology available in the early 80's to make a touring coupe.
I think of it as a modern steel rail coaster that has a highly flexible track!
Old 10-22-2002, 01:27 PM
suck my tail pipe
Frank B's Avatar
hehehe...good point
Old 10-22-2002, 01:36 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Now as I pick myself back up off of the floor, I've been the happy recepient of seals "resealing", both were on #$^&@%^*#%^@$%^!!! Fords I've owned. On one of them, weeks before every seal touching the block started leaking, NAY, STREAMING oil, coolant, windshield washer fluid (explain that one!).
80mph is my car's happy spot, I don't question providence, I just smack 'er on the arse and ride.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 10-22-2002, 07:43 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Thumbs up
Yeah I agree with 80mph..she just seems so happy there...oh bliss..glorious bliss...then again i ahve to get up in three hours and drive the CRX into brooklyn...GReat -chris
3days of cars and fun, 2weeks of garbage...dohhhhh
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 10-22-2002, 09:38 PM
fty fty is offline
fty's Avatar
I have just hit the 944 MARK !!!!!!!!!!!
Two pats one the ole back...
Old 10-22-2002, 09:40 PM
AFJuvat's Avatar
Professional diagnosis:
Exorcized/banished to a pit full of rabid wombats the evil random engine leak gremlins
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-23-2002, 07:27 PM
