tie rod rubbing sway bar 951
Hi All. its been along time since Ive been on. I wrecked my 951 back in 08 but after a couple of kids and a new house, iam back on the project.
Iam almost finish and I noticed that my swaybar is rubbing both tie rods. the rubbers are good on swaybar, but iam not sure when putting back together that I may have missed something. any help you guy can give would be greatly appreciated. maybe I have sway bar brackets on body backwards? just not sure . its been so long since I worked on it last. tie rods are new and not bent. I do remember the clearance being close back when I was driving it. Thanks all.
96 Tacoma SR5 4x4 (work truck)
2000 Tundra SR5 4x4 (work truck)
2005 Mazda 3s (wife's car)
70 914 (garage queen)
86 951 (fun factor)
Old 05-07-2015, 07:08 PM
Toofah King Bad
Rasta Monsta's Avatar
Sway bar upside down?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 05-07-2015, 08:03 PM
J1NX3D's Avatar
Originally Posted by rasta monsta View Post
sway bar upside down?
+1
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 05-07-2015, 09:52 PM
wow I feel stupid, Thank you, thank you! fixed now.
86 951 (fun factor)
Old 05-09-2015, 11:56 AM
Clearance on 968 30mm swaybar is very tight to tie rods when suspension fully extended. Im portant to tighten up the swaybar fixings with suspension loaded.
Quick check on the net and I see pics of swaybars mounted above and below A arm ... just for my sanity can someone confirm this is the right way
(Pic form prev post but same set up as mine)
Old 05-09-2015, 02:25 PM
9FF 9FF is offline
9FF's Avatar
iirc early 944's and all 924S's (all the steel arms) had them mounted on the top. All others are mounted on the bottom, except for some aftermarket like Welts which again are mounted on the top. Your 86 951 should be mounted on the bottom.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 05-09-2015, 02:51 PM
