Question Urethane bushings....Where to buy?
I am going to be doing some front suspention work and will replace all of the bushings. I have looked for urethane bushings with no luck. Does any one know where I can find some of these? It would be nice to buy them all as a kit if posible. Thanks ahead.
Old 11-09-2002, 10:20 AM
AFJuvat's Avatar
Performance products carries them.
Why are you goig with urathane? Are you planning on tracking the car or autocrossing?
For regular street use, the rubber ones are fine (and a lot less noisy)
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-09-2002, 04:39 PM
I was told they were better. What are the pros and cons of urethane?
While I'm at it.......The used sway bar (27mm) I have came with a post on the outer bushing. How do I mount this on my 83 944? Mine has a strap over the bushing.
Old 11-09-2002, 04:55 PM
SoCal Driver's Avatar
The ends are the same diameter as the bushings in the early sway bars. I've put the larger one from the 86 I parted out on the front of my 83 with no problems. Even put the rear sway bar on.
You do need to fix any oil and power steering leaks as these can rot out the rubber bushings should you decide to go that way.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-09-2002, 06:08 PM
Thanks So Cal,
Thats exacly why I'm doing the front end work. PS leak.
Just curiouse, Why was the bushing mount with the post used on later models? I tried to find prints with both styles but no luck.
Old 11-10-2002, 08:48 AM
The flexible front sway bar end mounting was used on the aluminum arms. There is a difference between the arc the arm takes and that of the end of the sway bar. The link is there to allow that difference to take place rather than have one fight the other in travel.
Old 11-10-2002, 10:22 AM
