marko's Avatar
Engine noise, front end, see video
This nasty little noise just started and I don't know what it is, but it sounds serious. Don't want to drive the car til I find out what it is. I'm talking about the groan/whine. Pitch gets higher with higher rpms.
Power steering belt removed. It's not the balance belt adjustment roller. Looking from the front of the car, it seems to be coming from the lower left quadrant of the engine. Could also be the lower middle section. S2 engine.
I'd like ya'lls opinions before I start tearing it apart.
Here's the noise
https://youtu.be/2yCD4bwrVhg
'90 944S2 cab - sold after 20 years, will not be forgotten.
'04 Mercedes SL500 - Nice but my S2 was more fun to drive.
Old 07-21-2015, 05:00 PM
Bradical's Avatar
It sounds like the balance belt idler pulley to me. You can run the car without the balance belt on it to check, it wont hurt your mounts it being off for that amount of time.
PCA - Florida Citrus Region
Old 07-21-2015, 05:03 PM
marko's Avatar
Not the idler pulley. I can spin it without any noise. It still spins freely after the engine shuts off as it is not touching the balance belt. Taking the balance belt off is a good idea to rule out anything associated with it. Prolly do that tomorrow night.
Old 07-21-2015, 05:54 PM
Try isolating the noise with an automotive stethoscope.
Old 07-21-2015, 06:24 PM
+1 - An automotive stethoscope is a relatively cheap tool, every toolbox should have one.
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 07-22-2015, 07:19 AM
theer's Avatar
Check the alternator belt. We had a similar noise on our '86 NA a/c delete.. turned out it was the wrong belt (too skinny). Especially under load - like when the cooling fans kicked on. New belt, correct tension, no more noise.
Old 07-22-2015, 10:53 AM
devin3200's Avatar
Hey Marko, The noise your car is make is similar to the noise my 87 na was making. I had to one loosing the tension on the balance belt and replace the pulley bearing on the a/c unit. You can take the belt of the a/c , for a temporary test. ( to see is the noise goes away). But i would start at the balance belt tension first to see if the noise goes away. Or at least calms down some. Good luck.
Old 07-22-2015, 12:46 PM
marko's Avatar
Power steering belt off, a/c belt off, balance belt off, noise is still there. With all that stuff off, it's harder to tell where the noise is coming from. I suppose it's time to get a stethescope as suggested and/or take off the timing belt and have a look see.
Ironically, it seems the engine runs smoother with the balance belt off. The lower balance shaft is very stiff. It takes some effort to turn the gear. I'll do some searching on that.
Old 07-22-2015, 04:38 PM
More Boost!
Since your 1/2 way there, check your lower balance shaft race to see why your binding/tough to turn over the lower bs sprocket, it should turn with hardly any effort.
Your timing belt pulley might be going bad? What year 87+?
Old 07-22-2015, 05:56 PM
More Boost!
Nothing else there, unless your wp pulley is going bad and the bearings are failing.
Old 07-22-2015, 06:05 PM
marko's Avatar
Timing belt tensioner roller kaput.
https://youtu.be/xAIveuV7gt8
Old 07-23-2015, 04:51 PM
More Boost!
Nice find, easy fix and you're back in business.
Old 07-24-2015, 07:47 AM
marko's Avatar
Well, the tensioner roller was bad, but replacing it didn't fix the noise.
It was the timing belt idler roller. Took it off, ran the car and the noise is gone.
Will start another thread on my balance shaft fiasco.
Old 08-22-2015, 10:08 AM
marko's Avatar
Well, that was premature, seems it was just a coincidence that the noise went away after removing that roller. Didn't notice it at first, but there is no oil pressure on a cold startup for about 6 seconds or so. Noise only goes away when car is warm, then shut off, then started back up again. Starting a new thread on that.
Old 09-19-2015, 05:57 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Hey Mark, did you turn the water pump drive by hand to see if the front sprocket is going? They sometimes make noise before they start to leak.
BTW, I love my seats. Putting "Casper" back together.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-19-2015, 10:12 AM
marko's Avatar
Hey Ralph,
Glad you love the seats, I aim to please.
Didn't try the water pump, problem is with the oil pressure somewhere. See my latest post, I have more details there.
Old 09-19-2015, 02:57 PM
944 addict
What's the header for the listing?
Old 09-19-2015, 03:01 PM
marko's Avatar
No oil pressure on cold start
Old 09-19-2015, 03:42 PM
More Boost!
Make sure your crank bolt is tightened to 155ft ft lbs, sounds like it loose and causing the no oil pressure, or your timing belt is loose and is not turning over your crank 1/2 the time.
Old 09-19-2015, 04:54 PM
