Dash lights fuse keeps blowing
Dash gauge lights fuse keeps blowing out in my 1984 944.
The dash lights up with a new fuse, once the car is started, blows out within a few seconds.
What troubleshooting would I perform to diagnose this issue?
Thanks in advance
Old 03-21-2016, 01:54 PM
Check the tail lights circuit also.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 03-21-2016, 01:55 PM
could you please explain more
Old 03-21-2016, 01:58 PM
plays with toy cars
sausagehacker's Avatar
IIRC there are a couple things on that circuit, including the gauges on the center console and maybe the cigarette lighter. Check the wiring diagram to be sure.
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 03-21-2016, 02:03 PM
Patrick
pfarah's Avatar
Rex,
Have you always had this problem or is it a recent issue?
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 03-21-2016, 05:46 PM
Originally Posted by pfarah View Post
Rex,
I've had the problem for about 4 months. Before then, in my previous two years of ownership the lights were good.
Old 03-21-2016, 07:04 PM
If you have a decent ammeter see how much current the circuit is drawing. A small DMM might not be big enough.
Usually the tail lights circuit is connected to the dash lights so the driver knows if their tail lights are out. Look at your fuse diagram for related fuses and pull anything for the rear lighting, then see if the instrument lights start working, that will narrow things down. A bad bulb socket out back somewhere like the licence plate lights would be suspect to me. Any dodgy rewiring done back there should be looked at.
Ash tray and glove box lights are likely connected, lighter socket likely is not. Aftermarket stereo wiring should also be considered. Miswiring the lighting circuit to the head unit could cause this. Pull the harness to the head unit.
1987 928S4
1992 968 cabrio
Old 03-22-2016, 06:08 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Rex Lt;
Does this happen also without starting vehicle and power + accessories is "on"
Reverse current and Ground loop is defiantly present.
Is vehicle store inside or outdoors?
If outside, rain may have grounded a printed circuit board or relay in fuse box; recommend start there...
keep us posted.
r
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 03-22-2016, 06:59 AM
Originally Posted by guru944 View Post
Rex Lt;
keep us posted.
r
vehicle is stored outside. The lights work fine before the vehicle is started, once started, within a couple seconds the fuse blows
Old 03-22-2016, 11:45 AM
Shifter's Avatar
I had a similar issue on a 968, and it was the dash light dimmer rheostat. Not certain if the early cars can have the same problem.
Old 03-22-2016, 02:46 PM
