Back in a Porsche but need a little help
Bought this car (86 944 NA) last fall and have been working on it over the spring to bring it back to life and eventually use it for 944-spec/cup. Finally got it road-worthy a few weeks ago. Had the confidence to try and open it up the other day and noticed a serious lack of power/bogging/misfire over about 5k rpm/WOT.
Then once you do let off the idle/throttle is very rough until it finally tries to even itself out or you gently give it gas and slowly let off. Car has new wires, new alternator, 2 degree timing advance, chip. Does this with or without any combination of the above. I did read somewhere that it could be a bad alt, but I haven't had a chance yet to remove that from the equation as the clutch master & slave are rapidly failing and I don't want to test without and be stranded with no alternator OR clutch. Here's the video of the behavior: https://www.youtube.com/watch?v=BHEnB7ZWe3U After filming the first vid, I noticed a puff of smoke about the 5k rpm spot as well, here's a video of that as well. It's not much: https://youtu.be/0e46wZ7RqFg At the end of the second video you can see me turn my hands up because the car returned to normal idle after sounding like a Harley at idle for about a minute. I've replaced plugs, wires, new alternator, checked compression (155,160,162,152 dry). Mileage unknown. Thanks in advance for any advice. |
Sorry for the double post . . ..
More Boost!
Too rich, black smoke, unburnt fuel. Check to see how much soot you have at the taipipe, if there is a exorbitant amt. of black soot there and by the bumper, then too much fuel is being dumped into the engine @ higher rpms.
You might have a bad afm(air flow meter), that is where your airbox connects to the throttle body. Sounds like not enough air and too much fuel, then black smoke appears when your car is running too rich at higher rpm's and the afm cannot keep up, then stumbles to maintain idle. You're close, I have a spare afm. A couple of minutes to swap it to see if it fixes it. Last edited by fiily; 07-25-2016 at 05:43 PM.. |
This is often a blown FPR or damper diaphragm. Pull the vacuum lines to these and check for fuel leaking into the vacuum line.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
More Boost!
No problem, hopefully it get's a bit cooler out, working on anything outside in 95 deg. with 72deg. dew point weather is not a pleasant experience.
Cap and rotor should be checked and the spark checked with a spark checker (for strength).
If you can get it to idle badly shut it down and see if any or all of the plugs smell like gas. One or more of the injectors might be sticky and hosing at higher duty cycle. If you plan to go racing you'll want them renewed as best you can anyway so it might as well be now. -Joel.
Seals and pintle caps won't fix a bad, sticky, clogged injector. You may need to have them serviced or at least clean and backflush them yourself although testing them properly takes some rigging.
under hood fuel leaks can be disastrous. you may have a leak in the injector housing.
I should have mentioned that I did indeed clean and backflush them when I had them out.
More Boost!
Jason, how does your cap, rotor, and plugs look?
Injector bodies have been known to leak. Small slick spot will show.
I can't really tell from the picture if any are too black. I had one plug blacker than the others and it turned out that that injector was leaking. The injectors had recently been refurbished. If the plugs are different colors then the mixtures are different so likely an injector issue.
1987 944 Summer 2006 E90 Winter |
Going to test fuel pressure this weekend and try swapping loaner parts. I like Fiily's theory that the pressure damper or regulator is either bad or not correct for the car. Would not be surprised to figure out that someone replaced the 2.5 bar regulator with a 3 or 3.5 bar (bigger is better, right?!)
More Boost!
No problem with using spares to see if it fixes you issue, and I hope it does and then you'll know what to replace without spending a fortune or chasing your tail with throwing new parts at the car.
I turned into a hot mess under that hood dying from the heat, man it was hot! Let us know how it turns out, and if you need any other stuff on loan for testing, let me know via PM or Text.
Well I haven't tested the fuel pressure yet, because the wrong adapter was shipped. The correct one won't be here until some time this week. I did swap over the loaner fuel rail - after having to replace the starter
- I went to start the car so I could pull the fuse and empty as much fuel out of the lines as possible and nothing. Just a tick. I just had the starter out like 2 days before to replace the clutch slave and of course it couldn't have failed on me then. Pulled it out again, tested it and sure enough it was really weak. Fortunately Autozone in Manchester had one in stock. So after I replaced that, I swapped out the loaner rail, fpr, fpd, etc. Still having the same issue. Over 5k she's rich and stumbles. I pulled the loaner off and re-cleaned the injectors before re-installing my rail just to be sure. I also see a balance shaft seal replacement in my near future. Good times. I guess it's to be expected with a car that sat for probably close to a year (maybe more) from the time the PO parked it and I finally got it back on the road. |
Can't thank you enough for sweating it out and taking a look for me. I owe you one, probably two.
