1984 944 no dipped beam
Hi all hope someone can help shed some light (literally) on my problem.
I have early 944 I can get full main beam but no dipped headlights, changed bulbs, fuses but still no look, ideas or thoughts much appreciated.
Old 10-27-2016, 06:52 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Light switch? Known to be troublesome
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 10-27-2016, 07:31 AM
Patrick
pfarah's Avatar
You may resort having to trace some wiring. I had an issue with the driver's side high beam. Turned out to be a burned out connection. Pull Connector A from the rear of the fuse panel and perform some visual/conductivity tests.
I ended up replacing the entire fuse block and connector A due to loose connection pins.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 10-27-2016, 03:55 PM
Pauld_94S2's Avatar
I once found the lever had come out of the indent in the switch in the steering column.
You could pull on the lever but it would not change the headlights.
Might also check there, or the steering column switch.
Old 10-27-2016, 07:12 PM
sweetskillsrk's Avatar
Had the same issue with my headlights when I first got my 944. After hours and days checking and troubleshooting I found a wire right behind the headlight assembly that had the insulation worn off and was grounding out against the back of the headlight frame. Where the headlight harness flexes all the time when the headlights go up and down, the wires were rubbing against each other and against the headlight frame. Check there on both sides, easy to get to and you don't have to take anything apart, hope that helps.
Landen
1988 Alpine White 944 N/A
Old 10-30-2016, 09:09 AM
