Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Porsche Crest 951 leaking oil exaust header side?
Silly question, I noticed slight dripping on the header side of my 951 engine block, I checked around the cyl head and cam box and didn't see any real leaks, it will smoke on start up, then after it warms up the smoke disappears. Could I be missing something, any idears on what could be leaking near the back of the header side of the engine?
Old 10-17-2016, 10:11 AM
cam tower gasket...
Old 10-17-2016, 10:20 AM
Originally Posted by v2rocket_aka944 View Post
cam tower gasket...
Thanks v2, there is no sneeking by a big issue here.....Time to prep for a headache....
Old 10-17-2016, 10:31 AM
It looks like the oil is coming from the rear cam housing cover, it might be time for a new gasket....I might get lucky!
Old 10-17-2016, 10:46 AM
no headache involved...cam tower gasket is stupid-easy...if it takes more than an hour, you had better be taking a 30 minute nap between taking it off and putting it back on.
Old 10-17-2016, 11:37 AM
Porsche Crest
I heard that, I saw another post, where someone said check the bolts, and that back gasket of the cam tower, ill check that first, then if it still leaks, ill do the "stupid-easy" gasket, Turning 50 yrs old makes me less wanting to bust up my knuckles, boy if I was younger, I would dive in to it with a big grin on my face, not so much now......
Old 10-28-2016, 10:58 AM
Arizona_928's Avatar
It's not that bad. Much harder to replace the mc heat shield! Lol
dolor et pavor
Copyright
Old 10-29-2016, 09:02 AM
