1986 porsche 944 n/a oil pump replacement
I just saw a deal on a 1986 porsche 944 with a bad oil pump and water pump.
I'm mostly concerned with replacing the oil pump, can you just lower the oil pan without removing the crossmember to change it?
Old 12-06-2016, 03:01 PM
I highly doubt the oil pump has gone bad.
They are very robust in the 944...likely has oil pressure issue the seller can't figure out.
Old 12-06-2016, 03:39 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Sometimes the drive to the oil pump becomes loose, because somebody didnt tighten it up properly. A 944 oil pump is a very expensive part incidentally.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 12-07-2016, 04:47 AM
The front pulley about has to be ready to fall of before the collar that drives the pump will disengage. I'd be looking at the Oil Pressure Relief Valve or the oil pick up in the pan is cracked first
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 12-07-2016, 05:02 AM
mistertate's Avatar
+1 I've had that happen. Oil pressure light after a numbskull did the belt job. Nursed it home. That might coincide with the water pump issue on your car.
You can replace the oil pump in the car, dropping the pan like you said. I've done it that way. It will be hard to pop off with the 732. Sometimes the pump drive sleeve can be hard to slide off the crank but heat and big pliers help.
OPRV or pickup are possible too, like dj says
Old 12-09-2016, 07:36 PM
Tags
1986 porsche 944 , 944 oil pump
