puddy's Avatar
Pros vs cons 924 GTR turbo build up or v8 swap
OK i don't know much about the 924 GTR other than I think they look badass and i'd like to build up a 924 into a GTR look one day, I know where I can get a 924 roller cheap. It will be a bare bones street car that I can drive to the track.
I'd like to keep a Porsche motor in it, perhaps a modified 951 motor or maybe a LS V8 swap if a Porsche build up is crazy money. I'm familiar with air cooled engine build costs and don't know if these water cooled 944 motors are equally as expensive to build or not. I was all around hotrodder before I became a Porsche fan, but for some reason it just doesn't seem right to me, to put a non Porsche motor in a Porsche.
Ideally i'd like a 400+ HP car, light weight track weapon. Is there a turbo porsche motor & trans that can be built to handle this power reliably and not for crazy money. Maybe in $10k range? If not maybe in LS swap is the way to go. I can do a lot of the work my self to keep cost down.
I read the 951 suspension can be swapped into the 924 for best handling. So i'd probably plan on that.
Any advise or relative links would be appreciated.
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 01-24-2017, 05:48 AM
9FF 9FF is offline
9FF's Avatar
Originally Posted by puddy View Post
...$10k range?
I'm no expert but I would think just the bodywork would cost $10k for the aftermarket GTR body panels, lights and half decent paint alone.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 01-24-2017, 06:23 AM
to get 400+ HP, & don't want to brake the bank, You need to look in to the LS. the 2.5 & the 2.7 are high to rebuild & hard to get real HP. the LS is cheap, & you get 350 hp with out doing anything. stick a supercharger, or twin turbo with the money you saved. who knows how much power you will end up with.. there are some haters on the LS swap. but look at the cobra, it is nothing but a V8 swap. & still the best car out there. they only go for a few million $$$ i to am workN on a 944n/a i have install a 5.4 LS im $2500.oo in the build. close to finished. cage, seats, & paint. $2000.oo 350+HP 944 porsche "with the turbo bumper cover" under $6000k with the car. i can run with any turbo for half the price. & with bolt-ons ill kill any 951 or ZO6.
Old 01-24-2017, 07:03 AM
400 crank HP is doable with a standard 2.5L 944 turbo engine.
Once you aim past that is where things get expensive.
Easiest way to get there is buying this kit:
http://www.lindseyracing.com/LR/Parts/951PACK340.html
Now some folks have said the "340 rwhp" number is a bit inflated but it'll get you pretty close to 400 true crank HP.
It'd be hard to do a decent LS swap for the ~$4k the kit above costs.
Old 01-24-2017, 07:22 AM
Toofah King Bad
Rasta Monsta's Avatar
Might be easier to backdate a cosmetically challenged 951 to look like a GTR.
This way, too, your project could go in stages while you enjoyed driving it.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-24-2017, 08:00 AM
I just read my post. it is not a 5.4 "i wish'' it's a 5.3 LS i hit 4 by mistake. BTW if you are lookN in to the 2.5L i have 1 i can let go cheap 80k miles you can hear run, & A 944N/A TRANSAXLE good motor just to weak for me. V8 POWER OR NOTHING
Old 01-24-2017, 09:15 AM
puddy's Avatar
The $10k i was referring to was just for the engine & trans hopefully... I know body work can be expensive. I'd like to try and tackle that myself, most of it anyways.
I'm not a talented fabricator, perhaps I can become one, so i'd prefer things that almost bolt together. So keeping a Porsche motor is the preference. Also I assume the 2.5 motor is lighter than a LS V8, but perhaps i'm mistaken. Does anyone know the stock weight of a 944 drivetrain?
Cheers, Chris
1986 951
Old 01-24-2017, 09:27 AM
puddy's Avatar
Thanks for the offer but i'm certain I can find most of what I need locally. But this whole thing depends on a particular 924 I know thats sitting i think I can get it for a nice low price. so i'll start with that and see how that pans out. Then i'll get more serious about which direction this whole project goes.
I also know if a high mile 1986 951 available, the car is in great shape and I can get it for less than market value. Perhaps it is smartest to backdate it. But i'd prefer to get the 924 and start with that as I understand they are lighter than a 944.
Cheers, Chris
1986 951
Old 01-24-2017, 09:33 AM
The newest of the noobs!
grendiers's Avatar
If you're thinking of the earlier 924 with the 2.0L motor, the 2.5L doesn't fit well, wrong motor mounting. The '87-'88 924S however, is a great candidate, 924 body, w/944 drivetrain. Check out Edredas's turbo build in his 924S: 924Board.org :: View topic - My narrow 951 project
1989 944 Turbo
2004 Jeep Wrangler Unlimited - Built!
1985 Saurer 6dm overland Swiss military truck/camper
Old 01-24-2017, 10:32 AM
weight of the LS is 30lb over the stock 2.5 take out A/C head lights, swap to a turbo bumper, & you are under weight of the stock 944. dont know bout the 924 but i think 924 is a little more weight then the 944. dont get me wrong the 2.5 is bad azz for its day. but that was 30yr ago... if you want to go fast, for cheep. buy the LS kit, go to the junk yard. get an LS under $500 .. its all bolt-on ... many video on the swap. im not the best at workN on cars, & i was able to get it done. you will need to beef up a n/a transaxle or get a turbo. but thats after you get it running & driveN It will be fine on the street.
Old 01-24-2017, 01:45 PM
9FF 9FF is offline
9FF's Avatar
You make it sound so easy but won't it be a very unreliable and underperforming car with na suspension, brakes, axles and trans with 350hp on tap. I've seen a few LS swaps and the ones I liked had at least $10k into the build and started off as 951's. Btw the 924 is a fair few pounds lighter than a 944, especially the later 944's.
Mike A
Old 01-24-2017, 03:35 PM
i just got done with the swap. i had the 944n/a transaxle drove fine on the road. just can't get down on it. so i got the 944 turbo transaxle LSD works great. 5.3n/a with 350hp been tuned.. stock suspension, brakes. you can work on a car and still drive it. im right under 6k. & even if i hit that 10k,. you no were i can get a 350hp 944 turbo for 10k??? so yes easy. + brakes are for quitter LOL i run mid 11 with a n/a there more then 1 way to skin a cat!!!!
Old 01-24-2017, 03:48 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Brakes are for quitters? Hope your car insurance company hasn't read your comment.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 01-25-2017, 03:59 AM
puddy's Avatar
How much power can a 944 transaxle handle? How easy is it to access spark plugs and header bolts etc once the LS is in the 944 chassis?
Cheers, Chris
1986 951
Old 01-26-2017, 03:01 AM
there are 2 kits, base & street & track, the base is $1500. you will need bellhouse & headers. the other is $2,100 but come will bellhouse headers & a stage 2 clutch. the n/a transaxle can handle 400lb so bout 300HP clean the turbo transaxle "i think" is 500lb so bout 400+HP .. i think the stock header will work. i dont know cuzz i got the street&track kit with headers.. now if you beef up the turbo transaxle, im sure it could handle 5 to 600HP
Old 01-26-2017, 06:09 AM
get on you-tube., start studyN, the 2.5 is a big motor, as big as the LS, so getN the ls in the 944 is not so bad. fits like it was made for it. a nice clean out the box look
Old 01-26-2017, 06:12 AM
ideola's Avatar
924Board.org :: View topic - Project Planning for 924 Performance Modifications
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 01-26-2017, 06:09 PM
