More Boost!
Stock or sleeved engine?
Tearing down a spare engine and looking for engine guru's help here. Is this a stock bore or has this engine been sleeved? Pistons are tolerance 1, 100mm mahle pistons with stock rods.
Old 08-14-2017, 09:02 AM
looks stock to me but very worn out...
if you clean it up (wipe all the oil away, use some brake cleaner to help clean better) a sleeve would be very obvious dark grey usually 3/32" or 1/8" thick.
you could always try a magnet..
Old 08-14-2017, 09:14 AM
More Boost!
Thanks spencer. I'll give the bores a good wipe down with some brake cleaner and post more pics.
Old 08-14-2017, 09:44 AM
Pauld_94S2's Avatar
To confirm, touch a magnet to the cylinder walls, no stick=aluminum, stick=steel.
Old 08-14-2017, 12:10 PM
not a great photo but you can see how much the sleeves "stand out" visually compared to the alum.
this was a 3.0L block i used to have.
Old 08-14-2017, 01:12 PM
More Boost!
Got the bores cleaned up a little more along with the pistons. Crank, girdle,rod/main bearings looked fine.
What should I do with a spare block, pistons, and crank now?
Old 08-14-2017, 06:15 PM
measure the bores, if in spec for roundness/taper you could probably do the paste-hone treatment and rebuild it with those pistons and new rings.
Old 08-14-2017, 09:08 PM
More Boost!
Selling block, cradle, crank, and pistons in for sale section. Just going to take up more garage space than I want, hopefully it will all go to a good home.
Old 08-15-2017, 09:24 PM
