Wire tuck?
Im just curious, has anybody here performed a wire tuck? I always thought the 944’s engine bay was a bit nasty and disorganized and its something i would like to do in the future as i shape this car into more of a show car instead of a semi-daily driver.
Coeur d'Alene, Idaho
Its intriguing to think of show car goals, which make something like that worth it. I think disturbing the old wiring on these girls is somewhat of a risk for a driver, but perhaps the results for you would be worth incurring that. Ironically, I bought a new fire extinguisher for mine today - Costco has a good sized one for $12 right now rated for electrical fires.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback. |
there was a guy who did it years ago but the photos were eaten by photobucket.
as mentioned, be careful handling the crispy 30 year old harnesses. i agree that there's way too much wiring and plumbing going on under there..
this is why I am having Timmy2 build all new custom wiring for my 78 930 show/go car.
good luck.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
Anyone with the needed electrical know-how could fabricate their own custom wiring harness. I'm certain that the needed connectors could all be sourced.
https://www.waytekwire.com/products/11/Multi-Pin-Connectors/ For most of us it seems a bridge too far, but if you've got show car dreams, why not? |
FYI FOR parts to build your own wiring harness:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/878135-diy-harness-connectors.html |
Personally I would build my own harness from scratch with tuck in mind. Some lengths needs to be modified. And stock crispy wiring most likely won't take bending more than 20-30 degrees without cracking. And the wires are most likely cracked where they go into the connector, peel back the rubber-boots and you'll see that easily.
