You are sure that it's TT bearings? And not rear wheel bearings?
I'm glad you were able to drive it to the show. And home. Did you happen to get any names of the other owners? On my trip back from Banner Elk, N.C, (1200 miles) I got 21 mpg- all highway and very fast. Cruise control was set. Speaking of....does your cruise control work?
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Yes, pretty sure it’s TT bearings. It makes the sound while stationary.
I didn’t get any of their names. Nope, cruise doesn’t work. Would be nice if it did, though.
Jonah Boyd 78 928 5 speed - #111 81 928 5 speed - the "Copper Turd" 81 928 Auto |
The cruise control is a silver box that sits on top of the tunnel under the console. It is accessed after removing the passenger side tunnel cover. IIRC, there are 2 -3 screws that hold it in place and once those are removed, the control can be slid out and detached from the connector.
If the vacuum to the cruise tested good, it is usually the solder joints inside the controller box that simply need to be re-flowed. There are probably a hundred solder joints in there to touch your soldering iron to, and it can be tedious but very doable. On the other hand, you could just send the controller to Roger, who has a guy that rebuilds them.
If you need help or want help with those TT bearings, just give me a call when you are ready.
hey 1982 - this is the guy stepson referred me to a couple of years ago - i think it's the same guy he is talking about - he did my cruise control and it's worked perfectly ever since
JamesDean59@gmail.com
84 928 S - SOLD 2012 Cayenne S |
Thanks for the info on the cruise unit! I'll pull it out of the car this evening if it cools off enough. I'm decent at soldering so re-flowing the joints shouldn't be too big of an issue! If the vacuum to the cruise is fed from the same source as is the AC controls, then that could also be why it doesn't work. I have a leak back there, and my CCU is in need of serious help (Fresh air blower doesn't turn off and the compressor always has voltage). I have that vacuum line capped off currently but it didn't work before I disconnected it. I'll address all of my issues at once while I have it apart.
If I get stuck on something or otherwise wind up needing help, I'll give you a shout! I've pulled the rear suspension and trans/TT out of an 83 by myself before, so I think I'll be ok on this one. I'll probably wind up working on it in the evenings after work a little bit at a time. Thanks for the offer! Thanks for the email address, Honerboys! I'll give him a shout if I'm not able to fix it myself.
Yes, that's the guy. He can fix your cruise control unit no matter what symptoms it shows IIRC.
But you've got to get your vacuum right first. The transmission vacuum down on top of the torque tube is one leg off the 4-way beyond the blue one way valve. The white line that goes throughout the firewall and feeds the vacuum manifold is another leg, the vacuum line that goes to the vacuum canister of the cruise control in the drivers side fender is another leg. Also, make sure your AC head unit is the correct part number. Basically 81-83 are the same, 84-89 are the same part number. Check your relay XXI (top row next to last relay on the right) should be a 53 relay for your fresh air blower. Or if the relay is okay, you could have a form of magic blower syndrome. No kidding!
I'll have to trace the vacuum system out! I saw where the blue one way valve hooks to a line that runs underneath the master cylinder and into the fender well.
I'll check the part number. The temperature slider is broken off of the CCU, as is the piece that's supposed to secure one of the cables to it. Someone (who shouldn't have been messing with a Porsche) has obviously been in there before - a few of the hoses were unhooked and one of the ports on the back of the vacuum switch was even plugged with a sheet metal screw.. I think I'll start searching for a better CCU. I might've bought one for my 82 6 or 7 years back but I can't remember. I'll have to look. I know the copper turd (which has a title and has been transferred into my name as of yesterday, yay!) doesn't have one in place, but it could be hiding elsewhere in the car. I'm not quite understanding on the relay part - "if the relay is okay", it could lead to the issue I'm having? Maybe you mean if the relay is bad? Thanks!
See: https://rennlist.com/forums/928-forum/1144683-int-fan-blows-at-max.html
I think I have the magic blower fixed. Messed around with the CCU a bit and after doing that the blower starting working correctly. I can also now hear the relay clicking whereas I couldn't before.
I still have an issue though. I have voltage but low current to the compressor anytime the ignition is on. It has just enough amperage to make the compressor clutch drag slightly. I have to manually jump 12v to the compressor for it to engage properly. I looked in the 83 last night and the unit does appear different to the one in my 81. The biggest difference (other than the design of the CCU face) I found is that the small panel that sits below the CCU doesn't have an "AC" push switch on it. Not sure if it would work in my 81 or not. My current head unit has part # 94.112.41.117 on it. It does have a bunch of vacuum hoses running to it. I think all of the early cars were vacuum operated. I could be wrong though.
Jonah Boyd 78 928 5 speed - #111 81 928 5 speed - the "Copper Turd" 81 928 Auto Last edited by 1982_928; 08-15-2019 at 04:18 PM.. |
What year is this car?
Car is an 81.
I’ll probably be able to figure the vacuum part of it. I’m going to pull the CCU out of my 83 and see how it compares.
I'm just about 100% sure that the AC head unit from the 83 will not retrofit to the 81. I'm pretty sure the 83 is first generation electromechanical. 84-89 are second generation.
You are correct - they will definitely not interchange. 83 is electromechanical.
Jonah, Did you get power to your compressor? AC is very nice to have this time of year in Texas.
I haven't had time to mess with it much more. Been busy with other projects. Got the correct TC bearings in a few days ago now I have everything I need to do the TT service.
It's also been really hot and muggy. No fun to work on cars in weather like this, but......
it'll soon be the best time to work on cars in Texas. Warm sunny skies, cool breeze. I love to work on 928s in the fall.
I was able to avoid the hot and muggy weather yesterday and today and take advantage of my Uncle's air conditioned shop and lift to do the TT and TC carrier bearings.
Not a terribly complicated job, but definitely time consuming. Being a guy I pulled the transmission without looking up instructions to do so.. Probably would've saved some time if I had. Biggest issue (which wasn't really that big) was getting the driveshaft out of the coupler up front - turns out there is a snap ring up there. It's been quite a while since I pulled the trans on my 83, but I don't recall that snap ring. Maybe the 4 speed cars are different. The bearings I pulled out made a little noise but were fairly smooth. They might have been making some noise but I don't think they were about to fail. All seemed to go well and hopefully I didn't mess anything up. This isn't a job I want to have to do again for quite a while. I don't believe anyone had ever had the transmission out in the past. There were paint marks on the TC bolts that were perfectly lined up (I assume these marks are factory, if they aren't maybe it's been apart before). I read one post where a guy claimed that his car only had 2 TT bearings rather than three as I was told it would have. My car only had 2, and it still had FAG bearings in it. I did notice that all of the control arms were marked "928 Inc." in paint marker - Maybe they came from 928 intl? Not really sure, but everything is tight and all of the bushings are in good shape. I would've driven the car home tonight but it appears that one of the brittle transmission cooler hoses at the transmission couldn't stand being removed and it sprung a leak. I did some research and it appears that the hose is 3/8". Is this correct? I want to be sure to buy the correct size hydraulic hose.
Jonah,
If you are speaking of the snap ring on the end of the TT, the snap ring and the spacers are what keep the 83 and older cars from having Thrust Bearing Failure. This method was done away with after the 83 model year, but I will tell you that the Stepson (84 Euro) still has the snap ring and spacers. I believe the AT cars had 2 TT bearings from the factory and the manual cars had 3. I'm sure that there is a metric size, but 3/8" could be usable.
Thanks! I used 3/8 and it fit very snug. Drove it home and all seems well.
The trans cooler hoses at the transmission were extremely brittle. I grabbed one of the ends and just barely touching it caused the hose to snap in two. Glad I got them replaced before they blew and sprayed hot ATF on the exhaust.
