Tim Boyer's Avatar
Air meter-fuse relay?
Hi,
Is there a fuse or relay associated with the air meter on a ‘84? Car will start with the air meter disconnected (idle fast) but will not start when air meter connected. Air meter is newly remanufactured,
Other ideas welcome!
Thanks,
Tim
Old 05-31-2021, 04:14 AM
stepson's Avatar
Tim, who remanufactured it?
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 06-01-2021, 09:39 AM
Tim Boyer's Avatar
Got it from 928 International
Old 06-01-2021, 01:28 PM
stepson's Avatar
Hmmmm. Any chance that anybody near you could put it in their car and try it?
Old 06-02-2021, 08:49 AM
Tim Boyer's Avatar
No
At first I thought it was a vacuum leak but that doesn’t seem to be the case.
Old 06-02-2021, 02:04 PM
If the MAF is under warranty get a replacement, it should run well with a properly calibrated one, if it run better without the MAF then it's sending the wrong info to the LH computer. There is no direct fuse for it.
Old 06-03-2021, 07:18 AM
stepson's Avatar
Pagno,
Tim has an '84 L jet, so he doesn't have a MAF, but has a "barn door" instead.
Old 06-08-2021, 10:21 AM
Tim Boyer's Avatar
I am starting to think that the wiring to the meter “barn door” is somehow the problem. How can I check this out?
Old 06-09-2021, 06:15 PM
stepson's Avatar
Tim, I wish I still had my "extra" barn door to send to you to try on your car for testing.
I have only ever had 1 L-Jet car and that was very briefly, yet somehow ended up with extras for L-Jet cars.
Unfortunately, my barn door is gone.
What you need is a pin-out for that connector.
Does anybody on Pelican have the Pin-out for the Barn door connector?
Old 06-10-2021, 08:40 AM
Tim Boyer's Avatar
Found a connector on eBay!
Now I am back to it not starting again whether meter is on or off��
Old 07-03-2021, 11:38 AM
