GUMBALL's Avatar
Battery Disconnect
1987 928 S4
I need some expert help here, regarding the battery disconnect.
As our car only gets driven about once a week, I have gotten into the habit of disconnecting the battery when parked in our garage.
I have been told that this was bad for the ECUs, that it causes a reset.
- Is this really an issue ?
- Am I better off leaving the battery connected and installing a battery maintainer ??
- is there a particular maintainer that is recommended ??
Thank you.
Old 12-28-2022, 02:28 PM
Linderpat's Avatar
It is not an issue to disconnect the battery as you do. Modern cars are more suseptable to this with the advanced computer systems in them. The 928 was pretty simple in this regard over its run. It is, however, a pain in the rear to access the battery and disconnect it. Instead, a battery tender is the best option. Get any decent one at your local parts store. The Battery Tender is a good option. You most definitely do not need a Porsche branded unit. Use the front jump post for the (+) and the bolt on the cross member for the (-) clamps. Alternatively, a lot of guys do use a quick disconnect to "unplug" the car. Honestly, driving once per week, you should never have to worry about the battery draining without doing anything, unless something else is wrong, causing a parasitic drain.
Ed
85 928 5 spd (guards red over tan)
07 Shelby GT500 6 spd (torch red over two tone black and red leather)
Old 12-29-2022, 03:22 AM
stepson's Avatar
Good Post Ed!
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 12-29-2022, 08:18 AM
harborman's Avatar
Originally Posted by GUMBALL View Post
1987 928 S4
Thank you.
I never disconnect the battery in my 928. Sometimes I don't drive it for a month or longer. But in winter I do put a small battery maintainer on it.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 01-06-2023, 11:40 AM
