Reverse lights on...
Hello Guys,
I have a 1987 928 S4. My reverse lights remain on even when I'm in D. The car has an auto trans.
Any ideas out there?
Thanks.
Sprint.
Old 09-28-2004, 09:16 AM
Check the back up light switch to make sure it is not stuck. If it checks out fine, check the relay in the panel and see if is is stuck. I mostly find the switch to be at fault, but have had a relay or two, and a ground wire cause this same issue.
Hope this helps
Kris Enniss
The European & Import Professionals
Mason, MI
517-676-1395
Old 10-05-2004, 12:14 PM
cuda876's Avatar
See i have a problem with the reverse lights but its totally opposite, my lights never come on. I subscribed to a 928 international magazine a while back....i called them and they were great help fixing mine...if you still have problems cal them, 714-632-9288....they were a big help!
Old 10-15-2004, 04:50 PM
Mine does a similar thing. But in drive D it manages to stay off. Then if I cycle the trans from R to P it will shut off in P. Otherwise it will remain on.
I did find a faulty relay... because they were never on at first. I replaced it and bingo I thought they are on... Whoops... they are on almost all the time now.
I think I will go back into the relay board and make sure the ground is properly connecting.
Any idea where the back up switch is? Or is it part of a PRND2 switch under the shifter area?
82 924 restored, 83 944 parting out
In search of 1988 or newer nice 944.
Old 03-26-2009, 07:38 AM
Network Native
Danglerb's Avatar
That magazine is the annual 928Intl parts catalog.
Old 03-26-2009, 11:20 AM
