NO substitute
Good luck. |
Petie3rd
to properly refinish the PU covers ( polyurethane ) they should be media blasted to remove the old finish. ( use walnut shells)
If there are already cracks in the paint then there is no way to fix the cracks unless all of the old is removed, anything the you put on top of the cracked parts will bleed through. Starting with a fresh surface is the only way to go.
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
I appreciate the advice.
1982 928 S Euro 5 speed |
Heavy Metal Relocator
if you really want to make short work of it, use a grinder with a 36 paper to remove paint from the metal surfaces.
using chemical is messy and not environmentally friendly, but some prefer this method. yes, a 36 paper is harsh, it will leave scratches that must be filled with a good filler primer and lots of block sanding. However, if your car has multiple paint layers (mine had 12 coats of paint), the 36 paper is the way to go. be very gentle on the aluminum pcs (hood, front fenders, doors, sunroof)....as they will warp easily. you can check with paint suppliers to see if there is a chemical paint remover for the poly bumper covers (I hear that there is), but again, be careful. Sanding these pcs may be the better way to go. Dad did his (below) totally by hand.....no chemicals. not bad for a 25 foot paint job, as he had less than $600 in the whole deal, plus his labor. ![]() Mine, on the other hand, may never get done......maybe the teenager will get motivated and finish it. ![]() --R
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
