harborman's Avatar
Horn location?
Ok, I found the alarm horn but where are the main horns? Mine seem very weak, probably from sitting a long time. I need to check them out.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 04-18-2010, 05:51 AM
mitsy's Avatar
mines are under drivers fender if that helps
1983 928s euro white
Old 04-18-2010, 06:44 AM
harborman's Avatar
Ok, I will look again. Mine quit working although the relay clicks. When they do work it sounds like a bicycle horn some kid would have on his little 3 wheeler!
1986 928S
32 valve engine
Old 04-18-2010, 07:08 AM
harborman's Avatar
Is it located possibly on the drivers fender under the head light? Maybe accessed by removing the wheel and a fender panel on the front of the wheel well. I could barely see in there from the front under neath.
1986 928S
32 valve engine
Old 04-18-2010, 07:33 AM
928: Serial Enabler
Yes.
How did you find the alarm horns? They are pretty well hidden.
84,85,86 928 cars
Old 04-18-2010, 08:14 AM
MPDano's Avatar
Originally Posted by Landseer View Post
Yes.
If it's aftermarket, then this would depend on the installer. I have an alarm horn right under the front bumper. Very easy to disable if need be by a crook. In another post, I had the alarm box actually fall under my brake pedal while I was driving. Most Alarm Installers aren't the sharpest tools in the shed. At least in my experience.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-18-2010, 08:19 AM
harborman's Avatar
Yes.
I thought the alarm horn was on the fire wall by wipers, if I read the shop manual correctly?
I am looking for the driving horns, so if some jerk cuts me off I can sound the horns big time!
1986 928S
32 valve engine
Old 04-18-2010, 08:22 AM
MPDano's Avatar
Good luck if your expecting loud truck horns. The European Horns sound like a Rat being stepped on.
Old 04-18-2010, 08:25 AM
harborman's Avatar
I have the factory alarm in mine, but where are the driving horns? I think up behind that left head light, hard to get to except maybe through the wheel well via access panel. I am not sure, can't really see in there except from through the grill below. Something looks like a horn but not sure.
1986 928S
32 valve engine
harborman's Avatar
Mine sounds like a kids tricycle when it works, really pimpy!
I might put some GD air horns in it so the old lady who cuts me offs hair stand up and she wets her pants when I blow them !!!
1986 928S
32 valve engine
Old 04-18-2010, 08:31 AM
Petie3rd
Mrmerlin's Avatar
the horns are under the front of right fender,
remove the wheel then the fender liner if it has one then the front block off plate
The alarm horn is under the windshield cowl on the right of the blower motor as sitting in the car
Old 04-18-2010, 08:48 AM
Petie3rd
Mrmerlin's Avatar
if you want new horns go to PEP boys and buy the Fiamm horn set there is a low and Hi they will bolt in and they are rather loud
Old 04-18-2010, 08:49 AM
harborman's Avatar
Thanks Stan,
I think I might just do it after I check out the stock ones and find out why they are intermittent.
1986 928S
32 valve engine
Old 04-18-2010, 09:12 AM
928: Serial Enabler
While your in there, its a decent time to address the windshield and headlight washer unit in the rear of the front fender.
84,85,86 928 cars
Old 04-18-2010, 09:14 AM
Petie3rd
Mrmerlin's Avatar
what Chris said and remove both of the metal collars in the tank inlet and fill tube outlet as well as flush out the tank
Old 04-18-2010, 01:45 PM
928: Serial Enabler
I did a rennlist write up on it. Will post a link later. Burgers burning.
84,85,86 928 cars
Old 04-18-2010, 04:23 PM
928-Electrics Guy
Alan in AZ's Avatar
They are indeed in the front drivers side fender under the headlight as first noted... but only if you have a RHD car...
I second the idea of better horns - my stock horns sounded like an apology rather than a warning....
Alan
1994 928 GTS Black/Black Manual
Old 04-21-2010, 04:31 PM
harborman's Avatar
Alan
Alan, now I am confused, someone said they were under the "right" passenger side. Mine is a US car normal placement of steering wheel. If they were working I could have someone blow the tweeky things and see, but unfortunately they are not working, except relay clicks. They did send out a puny sounds a few times, not enough to scare a church mouse!
1986 928S
32 valve engine
Old 04-21-2010, 05:54 PM
928-Electrics Guy
Alan in AZ's Avatar
Err - now lets think about this one....
RHD = Right Hand Drive... as is usual in Glasgow Scotland
So the drivers side fender is...
Old 04-21-2010, 07:22 PM
stock horns should be located in front of the right front wheel. As far as I can tell from the parts catalog (and from both my cars), two separate horns are factory mounted. Part. nr. 911 635 101 20 (fanfare high pitch) and 911 635 101 00 (fanfare low pitch).
I found another horn in front of the left wheel as well, but this turned out to be an aftermarket installation - and a really crappy wirering job at that,
Old 04-22-2010, 06:30 AM
