Horn location?
Ok, I found the alarm horn but where are the main horns? Mine seem very weak, probably from sitting a long time. I need to check them out.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
mines are under drivers fender if that helps
1983 928s euro white
Ok, I will look again. Mine quit working although the relay clicks. When they do work it sounds like a bicycle horn some kid would have on his little 3 wheeler!
Is it located possibly on the drivers fender under the head light? Maybe accessed by removing the wheel and a fender panel on the front of the wheel well. I could barely see in there from the front under neath.
928: Serial Enabler
Yes.
How did you find the alarm horns? They are pretty well hidden.
84,85,86 928 cars |
If it's aftermarket, then this would depend on the installer. I have an alarm horn right under the front bumper. Very easy to disable if need be by a crook. In another post, I had the alarm box actually fall under my brake pedal while I was driving. Most Alarm Installers aren't the sharpest tools in the shed. At least in my experience.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
I am looking for the driving horns, so if some jerk cuts me off I can sound the horns big time!
I might put some GD air horns in it so the old lady who cuts me offs hair stand up and she wets her pants when I blow them !!!
Petie3rd
the horns are under the front of right fender,
remove the wheel then the fender liner if it has one then the front block off plate The alarm horn is under the windshield cowl on the right of the blower motor as sitting in the car
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Petie3rd
if you want new horns go to PEP boys and buy the Fiamm horn set there is a low and Hi they will bolt in and they are rather loud
I think I might just do it after I check out the stock ones and find out why they are intermittent.
928: Serial Enabler
While your in there, its a decent time to address the windshield and headlight washer unit in the rear of the front fender.
84,85,86 928 cars |
Petie3rd
what Chris said and remove both of the metal collars in the tank inlet and fill tube outlet as well as flush out the tank
928: Serial Enabler
I did a rennlist write up on it. Will post a link later. Burgers burning.
84,85,86 928 cars |
928-Electrics Guy
They are indeed in the front drivers side fender under the headlight as first noted... but only if you have a RHD car...
I second the idea of better horns - my stock horns sounded like an apology rather than a warning.... Alan
1994 928 GTS Black/Black Manual |
Alan, now I am confused, someone said they were under the "right" passenger side. Mine is a US car normal placement of steering wheel. If they were working I could have someone blow the tweeky things and see, but unfortunately they are not working, except relay clicks. They did send out a puny sounds a few times, not enough to scare a church mouse!
928-Electrics Guy
Err - now lets think about this one....
RHD = Right Hand Drive... as is usual in Glasgow Scotland So the drivers side fender is...
stock horns should be located in front of the right front wheel. As far as I can tell from the parts catalog (and from both my cars), two separate horns are factory mounted. Part. nr. 911 635 101 20 (fanfare high pitch) and 911 635 101 00 (fanfare low pitch).
I found another horn in front of the left wheel as well, but this turned out to be an aftermarket installation - and a really crappy wirering job at that, |
