Boge Front shock differences
I'm updating 1982 non adjusting front shocks (probably the originals) to later adjustable type.
Originals were Boge, replacing with Boge.(I know Koni, or Bilstein better, but it's a cost thing)
I have the adjusters,I hav'nt stripped front suspension yet, (need to leave alone for a while so I can move car around the garage.)
Questions:
Is the early type lower spring perch re-useable?
There is a difference in shock part number early 928 343 055 04
late 928 333 055 09
Do I stick with the original ? or go with the later?
Is the upper spring retainer etc the same?
What are the differences between the two?
are they interchangeable?
Old 05-27-2011, 04:06 PM
Petie3rd
Mrmerlin's Avatar
the upper rubber should swap over,
call 928INTL and buy used lower perches and adjuster collars and threaded rings then when you get things apart you will have all you need to make it work,
return the lower perches if they are the same
Old 05-27-2011, 06:28 PM
Pete R's Avatar
I'm not sure of your numbers but there are 2 style Boges. I reccomend the gas ones. They were a direct replacement for my non gas Boges. Not a bad shock for street use.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 05-27-2011, 07:07 PM
Petie3rd
Mrmerlin's Avatar
IIRC the only shocks available now are the gas filled Boges
Old 05-27-2011, 08:07 PM
I allready have the rings and collars, more interested in actual differences between early and late ones,
Same position of the ring retaining "bumps" ?
Do they have the same shaft diameter?
Diferent diameter bottom mounts?
Different pressures?
What's the difference?
Old 05-27-2011, 10:52 PM
Looks like the only difference here is the shock part number
(and the PRICE! comparison Porsche /OEM replacement!)
Porsche 928 Porsche Parts And Accessories Parts
Old 05-27-2011, 10:58 PM
stepson's Avatar
You will need to change springs as well. The earlier non-adjustable springs are taller and have an extra coil versus the adjustable type springs.
Shaft diameters are the same, but you have to have new lower perches.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 05-28-2011, 06:18 PM
Springs no problem, they were going to be replaced anyway,
Any reason for needing to replace the lower perches?Diferent spring diameter perhaps?
Old 05-28-2011, 06:59 PM
Pete R's Avatar
The Eibach spring set improved my handling and dropped the car about an inch.
IIRC the non adjustable spring perches are made to set on the shock tabs, the adjustable ones are made to set on and work with the adjuster
Neon SRT4 track car
Old 05-28-2011, 07:43 PM
I see, obvious now you have pointed it out, would need more meat on the non adjust type centre to grab on., Springs when I get there will be made local, might look to machining my existing bottom perches to suit if it's possible.
Still need to know the shock difference , Anybody?
Old 05-28-2011, 08:05 PM
Finally found it, on a German site (in German), externally look nearly the same, big difference is what's inside.
928.343.055.04 is hydraulic- oil
928.333.055.09 is Gas
New question, gas looks like the one to go for as Porsche went from hydraulic to gas,I don't think they would go backwards.
Anyone that knows shocks got an opinion?
Old 05-29-2011, 12:29 AM
Pete R's Avatar
The shocks aren't actually gas. They are still oil but in a pressurized gas chamber. The gas helps keeping the oil form aerating under movement and thus keep the dampening more consistent.
Neon SRT4 track car
Old 05-29-2011, 06:17 AM
So the gas type is a better system?
Old 05-29-2011, 04:02 PM
Pete R's Avatar
yes.
Neon SRT4 track car
Old 05-29-2011, 06:55 PM
Old 05-29-2011, 09:16 PM
