Anyone willing to lend me their flywheel lock?
I've got a 79 auto and wanted to see if there was anyone in the Portland area that would be willing to lend me their flywheel lock?
Thanks!
Old 08-22-2011, 11:36 PM
harborman's Avatar
Thanks!
They are not that expensive and if you keep the car you will need it again. I would buy one if I were you.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 08-23-2011, 05:19 AM
You don't need one ? just use a 1/2 Impact Gun with a Impact Socket that fits tight and plenty of Air pressure ( like 120 ) comes right off. Only way that wont work is if you have a crummy Gun.
Old 08-23-2011, 10:18 PM
I was going to try that actually but I'll have to move the radiator out of the way so my impact gun will fit. I've got a decent gun so I expect it'll do the job. Id rather not buy the lock if I can avoid it.
Old 08-23-2011, 11:10 PM
MPDano's Avatar
I can lend you mine, but that's $10 to and from. The $50 investment for the Tool is worth it. You will for sure need it again in the future. Your call.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-24-2011, 05:45 AM
If the impact doesn't work out I'll pick one up. Thanks for the offer but it only makes sense if I were borrowing it from someone local.
Old 08-27-2011, 10:25 AM
harborman's Avatar
If you are doing the timing belt you must make sure the crank does not move after setting everything and the flywheel lock prevents it from moving. Not sure why you are removing the harmonic balancer, if that is what you are doing.
1986 928S
32 valve engine
Old 08-27-2011, 12:08 PM
You're saying I don't have to remove the harmonic balancer to replace the tb? I dont see how it's possible to slip the belt in/out without removing it. I'm using http://www.928intl.com/repair/T-belt1.pdf as reference but had the engine out and apart when i did it last so I didn't run into this issue.
Old 08-27-2011, 08:30 PM
MPDano's Avatar
Yes, HB "must" be removed in order to get the lower TB Cover off. Also, when putting the HB back on, make sure the writing reads towards the front of the car. A lot of backwards HB stories out there.
Old 08-28-2011, 03:40 AM
harborman's Avatar
Yes, to remove the bottom cover you need to remove the HB. However, since you are doing the timing belt, it is important that the crank not be moved once you have it set at proper position. What I did was set the crank and cams at the proper position to remove the belt, then place the flywheel lock on and then remove the balancer. Once finished with the job, place balancer back on and remove flywheel lock.
1986 928S
32 valve engine
Old 08-28-2011, 05:12 AM
