Shifter Coupler Bushing
OK guys - I need assistance again. I have heard that the shifter coupler bushing is a much needed replacement part after 30 years and my shifter is rather vague. I know how to find 2nd and the others, but I'd rather fix it if I let the wife ever drive. At $13, it is not the price of the part, but the labor that gets you. Where is this part located and how do I replace it? What is in the way? How many drinks will it take? I do have a lift to ease the pain. Thanks ahead of time. Bob
I’m Porsche-less! 2010 AMG E63 - what an engine! BMW K1200R - Hang on! 1987 Porsche 928 S4 - SOLD. 1981 Porsche 928 Saved & SOLD. 1976 Porsche 911 S (V8 Race Car) - SOLD.
Yes I'm blue collar, all my white ones got dirty!
Old 09-08-2011, 10:36 AM
stepson's Avatar
Without a lift, it's a two drink job.
With a lift, it's a one drink job.
Put your car on the lift, at the front top of the tranny, you'll see it under the dust boot. Mark and note the position and location of the shift coupler before removing. Undo the 10mm(?) pointy ended bolt that secures it to the shaft and remove it. Put the new bushings on, position it, check that it goes into all the gears, tighten it down, and the hardest part.....pull the new dust boot up over the repaired shift coupler.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 09-08-2011, 10:36 PM
Architecture & Porsche's
If you're having a hard time finding gears, it's probably the rear u-joint coupler: you can remove and rebuild this using a small hand (bearing) press and the 914 u-joint rebuild bushings.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 09-09-2011, 06:23 AM
