recommendations for adhesive??
I need to glue the vinyl along the upper door frame back to the plastic - does anyone have a strong recommendation for a particular adhesive that I should use?
81 Light Blue 928 with tan interior, 4.5L Auto 83 Champagne 944 2001 Boxster, base 2.7 |
Network Native
This needs a picture, I can't guess which part you mean.
I'll try and get a pic - its the molding that runs all along the upper portion of the door (the frame around the window - not the pillar). At the most rearward portion it actually encircles the door lock (the post, not the knob). Sorry - I could have/(SHOULD have) been more clear the first time.
The vinyl has started to peel off the plastic backing (the part that clips INTO the door frame), and is hanging down across my window... I would also imagine that its worth the effort to remove the old adhesive - acetone, perhaps?
3M Weatherstrip adhesive. That stuff takes a little bit to set up, but once it does. Oh yeah!!!
1986.5 928S Guards Red A4 stock I think. And a whole gaggle of GM V8's Vette, Firebirds, GTO, ImpalaSSs, etc none of them stock. |
If it's vinyl or fabric.. 3m Super trim adhesive or a less sticky gereral trim adhesive
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
1978 928 - 9288200072
I used Gorilla Glue on mine. On the window frame piece, I applied the Gorilla Glue and held it in place with spring clamps. The plastic was broken where it encircles the door lock and the Gorilla Glue did a good job of gluing it back together as well.
1978 928 - 5 speed - no sunroof - Copper Brown Metallic - Cork Interior |
Be careful with Gorilla Glue as it does expand amd get all over thw place, but it stronger than sheeit.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
3M super 77 works very well also. Used quite a bit of it at the upholstery shop I worked at years ago.
Thanks guys - will let u know how it goes!
