Originally Posted by kelanel View Post
Yes, passenger side front is #1, counting towards the back and drivers side front is #5. you should also have the firing order engraved on the passenger side cam tower right above the porsche letters. there should be numbers also on the distributor cap where the plug socket in that list the cylinders the wires lead if you feel like checking that for any reason as well (my new cap has them).
Hope this helps,
Jonathan.
yes i see the firing order and the numbers on the cap. I just didnt see the numbers on the cylinders.
Only other thing i need to know for sure is if 0/1 is TDC.
Im sure its out of time.
1981 black 928
Old 06-05-2012, 11:44 AM
stepson's Avatar
You should be able to read the numbers/letters correctly oriented on the harmonic balancer from the front of the engine. If the harmonic balancer is on backwards, you will have spark, compression, and fuel, but not all three at the right time. Your car will not run.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 06-05-2012, 01:02 PM
Network Native
Danglerb's Avatar
Except that this car starts each am.
Old 06-05-2012, 01:52 PM
MPDano's Avatar
Is that "am" PST, CST or EST?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-05-2012, 02:00 PM
First off I want to thank every one for playing. But unfortunately there can only be one winner. And that prize needs to go to stepson with the reversed balancer. Second prize goes to every one that mentioned bad grounds. There were lots of them . End result is I was able to get it running enough to sell it . I'm sure the new owner will be starting his thread shortly so stay tuned for part 2 of the 928 game.
1981 black 928
Old 06-09-2012, 06:13 PM
Kool
AirtekHVAC's Avatar
Really? Does that warrant unloading it? I don't understand why the HB is a big problem. I have read several threads about this...are the mechanics out there that dumb??? What damage occurs when this happens?
Old 06-09-2012, 07:19 PM
stepson's Avatar
Airtek,
Maybe Sundown was a dealer needing to move a car. Either way, hopefully the new owner will take a shine to the car and take care of it. I don't mind helping either way, but it would have been nice to know who you're dealing with.
There is no damage at all with the HB on backwards on a non-interference engine. It just won't run. It is maddening. You have fuel, spark and compression, but not all at the right time. To put the HB back on correctly is just the same as redoing a TB job all over again. The TB has to come off and the cam gears have to be reset in conjuction with the reoriented HB.
Old 06-10-2012, 12:53 PM
Kool
AirtekHVAC's Avatar
I see.... To me, anyway, if no damage done, seems like he would have been excited to have it fixed....perhaps your right, and he was looking to unload it anyway.
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 06-10-2012, 05:26 PM
There wasn't any damage to the engine from the HB. It was just the last straw in a very long list of problems the car had. I bought it with the intent of fixing it up to keep. But After realizing the extent of the work needed I knew it was more of a project then I wanted.
I didn't unload it . I was made an offer for it from a fellow pelican who had been reading my posts from the start and was well aware of the cars problems. I was well pleased with my self I got to hear it run. In my mind I won. Thanks to every one here .
1981 black 928
Old 06-10-2012, 05:47 PM
Kool
AirtekHVAC's Avatar
Good deal sundown, no offense meant, just curious....as I have found, as have many others, it takes a lot to keep these things going, like any old car.
Jeeps (early Chrysler Cherokees / grand in particular) come to mind as vehicles that require a lot of "constant tinkering"...boy do I have some stories there....always something broken....
Ron
Old 06-10-2012, 06:50 PM
stepson's Avatar
+1 to Airtek's comments above, Sundown.
928 Projects are not for the faint of heart and can be very defeating. Most people never realize their limitations. It is very good that you realized that you had come to the end of your road with this particular car. But, Is there is no greater sound than that of an engine you have been working on starting?
In my mind, you won also.
Good Luck to you and maybe we'll see you down the road.
Old 06-10-2012, 08:07 PM
oh yeah im hooked big time, I will own aother one . But if im going to put in that much time , money and effort I want it to be a model more worthy of the investment.
1981 black 928
Old 06-10-2012, 08:24 PM
