Porsche Crest fixing broken door handle on 1982 928
i broke the door handle when it was really cold , and im just wondering what i need to do to fix it, and is it a really hard job? its a 1982 928. any help would be awesome!
Old 02-12-2013, 08:42 PM
MPDano's Avatar
Yup, you'll need fingers like ET or hands the size of a 5 year old. To make the job a whole lot easier, remove the glass first, then you'll have the room you'll need to do the repair. A door handle break is very common on our cars, so don't think the Spinach is what caused this.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-12-2013, 08:52 PM
Fixer's Avatar
I removed mine for painting without removing the glass. Glass was lowered all the way, door panel was off and outer door glass scraper was off.
Try without taking the door glass scraper off that is a pain you may be able to get down in there.
He needs a replacement handle if the cast metal has broken. Anyone have one??
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 02-12-2013, 09:10 PM
thanks for the help guys. im guessing 928 International-Left Door Handle Hinge is the part i need to buy to do the repair? and i need to adjust that glass anyways so i guess ill do that while the door is apart lol
Old 02-12-2013, 09:48 PM
Pete R's Avatar
Common problem. I found the fix to be easy, once the door panel was off. I believe I did it with the window all the way up. The hardest part for me was snapping on and off the plastic connectors. It's very self expanatory once you get in there.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 02-13-2013, 05:14 AM
Petie3rd
Mrmerlin's Avatar
remove the door panel,
put window down,
remove bolts for the security panel
put window up,
if the handle is good IE no snapped off tang tape it into position on the door with blue tape
Remove the door handle mechanism,
install new mechanism
lubricate the interior door latch with oil
install the security plate ,
put window down install remaining hardware,
install the vapor barrier ,
install the door panel
Old 02-13-2013, 08:09 AM
Kiln_Red's Avatar
Well said. Door handle job isn't a particularly fun or straightforward job on the 928.
put window down,
put window up,
Good instructions here. This covers everything that comes to mind. Good luck! Enjoy your handle in good health.
Old 02-13-2013, 09:04 AM
MPDano's Avatar
Yupper. There was a reason I needed access from the top, which is why I suggested to remove the glass (2 10mm bolts I think). By doing this it eliminated about 80% of my cusswords during this job.
Old 02-13-2013, 09:08 AM
Stoolie's Avatar
Replacing a door handle hinge is a 928 rite of passage!
Best story I saw was the chap that gave a neighborhood kid $5 to hold it in place while he screwed it in - he was stoked to get the fix done, kid was strutting around saying he fixed a Porsche. Win/win!
1991 928 S4 - Horizon Blue
Old 02-13-2013, 12:31 PM
MPDano's Avatar
I remember that story
Old 02-13-2013, 12:34 PM
Fixer's Avatar
put window down,
put window up,
Stan, I am starting to think you may be a super computer and not human.
Matt
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Old 02-13-2013, 01:54 PM
Network Native
Danglerb's Avatar
Long and skinny or with a builtin flashlight?
Old 02-14-2013, 12:35 AM
Kool
AirtekHVAC's Avatar
Yes
Old 02-14-2013, 04:14 AM
MPDano's Avatar
Both would work better.
Old 02-14-2013, 08:36 AM
On my 79 the driverside doesn't lock it just spinns a little but passanger locks fine...... how can I fiz this?
Old 02-14-2013, 01:34 PM
MPDano's Avatar
You should probably start a new thread as this is totally different. Also, when you do post. Be exact on what is spinning? The key in the tumbler or the electric motor that spins the assembly in door.
Old 02-14-2013, 02:05 PM
Tags
broken , door handle , fix , help me , problem
