i broke the door handle when it was really cold , and im just wondering what i need to do to fix it, and is it a really hard job? its a 1982 928. any help would be awesome!
Yup, you'll need fingers like ET or hands the size of a 5 year old. To make the job a whole lot easier, remove the glass first, then you'll have the room you'll need to do the repair. A door handle break is very common on our cars, so don't think the Spinach is what caused this.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
I removed mine for painting without removing the glass. Glass was lowered all the way, door panel was off and outer door glass scraper was off.
Try without taking the door glass scraper off that is a pain you may be able to get down in there. He needs a replacement handle if the cast metal has broken. Anyone have one??
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels Last edited by The Fixer; 02-12-2013 at 09:15 PM.. |
thanks for the help guys. im guessing 928 International-Left Door Handle Hinge is the part i need to buy to do the repair? and i need to adjust that glass anyways so i guess ill do that while the door is apart lol
Common problem. I found the fix to be easy, once the door panel was off. I believe I did it with the window all the way up. The hardest part for me was snapping on and off the plastic connectors. It's very self expanatory once you get in there.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Petie3rd
remove the door panel,
put window down, remove bolts for the security panel put window up, if the handle is good IE no snapped off tang tape it into position on the door with blue tape Remove the door handle mechanism, install new mechanism lubricate the interior door latch with oil install the security plate , put window down install remaining hardware, install the vapor barrier , install the door panel
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Replacing a door handle hinge is a 928 rite of passage!
Best story I saw was the chap that gave a neighborhood kid $5 to hold it in place while he screwed it in - he was stoked to get the fix done, kid was strutting around saying he fixed a Porsche. Win/win!
1991 928 S4 - Horizon Blue |
Matt
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
Network Native
Kool
Yes
Both would work better.
On my 79 the driverside doesn't lock it just spinns a little but passanger locks fine...... how can I fiz this?
You should probably start a new thread as this is totally different. Also, when you do post. Be exact on what is spinning? The key in the tumbler or the electric motor that spins the assembly in door.
| Tags |
| broken , door handle , fix , help me , problem |
