1982 928S
georges 928S's Avatar
jacking points
Hi Guys, i was trying to jack my car up and all i see a 2 inch diamater hole, isn't there suppose to be some kind of plate that goes in that hole so you can place your jack under there. Thanks Ed.
Old 08-27-2012, 08:57 PM
Kool
AirtekHVAC's Avatar
I put my jackstands right onto the round pads...I did not like it, and did not feel safe....I ended up putting stands all over the darn thing...
I just ordered a set of these: Liftbars
I can't wait to get them!
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 08-28-2012, 04:47 PM
1982 928S
jacking points
thanks Ron for answering me, can these lift bars be used on different cars or just the porsche 928. Thanks again. Ed.
Old 08-28-2012, 07:07 PM
19psi's Avatar
They are made specifically for the 928 and even at that it appears there are two different types depending on whether you have the round pads or square. If your pads are missing, they may not be safe to use.
Are all four of your pads missing? Any pictures?
George in Indiana
928 Weissach #153
Cayenne S
Old 08-28-2012, 07:14 PM
Arizona_928's Avatar
I have a set that goes inside the hole and supports the front end that way.
dolor et pavor
Copyright
Old 08-28-2012, 10:21 PM
1982 928S
jacking points
Hi Levi, does these screw in the hole or how do they work, i may be interested if you send some pictures you can e-mail me at( edmondgeorge@hotmail.com) Thanks Ed.
Old 08-29-2012, 10:05 AM
harborman's Avatar
You can jack up the rear from the support underneath about middle and behind the trans as I recall. It's a cast aluminum piece. I use a small block of wood on the floor jack, then place your jack stands on those jack points. In the front, you can jack up on one side on a frame part in front of the the wheel just enough to get the car up so you can then place a 2x4 on your jack and position it on the support behind the pan. I got this from Mrmerlin sometime ago. Do a search on his post, it may have pictures.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 08-29-2012, 11:33 AM
