everything
hello i am new on this form.need som help,but first. hello
Old 10-04-2012, 12:30 PM
928 Newbie
dcrasta's Avatar
YO . Welcome to Pelican
Ask and you shall receive.
Old 10-04-2012, 12:38 PM
everything
wat will happend if the charging are eksampel 12,6.can it efects some sensors,like the auxiliary air regulatoror and mayby the cold start valve
Old 10-04-2012, 01:04 PM
Network Native
Danglerb's Avatar
Don't trust the pod gauges, use a real meter at the jump post or the battery, and no 12.6v should not be any issue for sensors, but it does not indicate the alternator is charging.
Old 10-04-2012, 01:31 PM
everything
the auxiliary air regulator has 21 ohm, it shoud be between 40 and 75 i think.time to change maybe.the temp time switch has right ohm when cold between w and ground also when warm,buy between g and ground when cold, 35 ohm,should be 0 ohm.and when warm 35 ohm.
Old 10-04-2012, 01:54 PM
mikeesik's Avatar
hello. What you got ?
Formerly from ratslist.
AMG E 55..2002.
Lotus Esprit SE. 1990
Old 10-04-2012, 02:26 PM
dont undrstand what you mean,what you got
Old 10-04-2012, 02:45 PM
mikeesik's Avatar
What year 928 do you have ?-Standard -Auto?/ Mileage/shape?
Pics?
AMG E 55..2002.
Old 10-04-2012, 02:50 PM
1981 928s europa.
Old 10-04-2012, 02:53 PM
mikeesik's Avatar
Pictures ?
Thanks.
AMG E 55..2002.
Old 10-04-2012, 02:59 PM
first day on this forum.it will com picture later.my name is johnny 44 year from lødingen in north of norway.have lots off problems.
Old 10-04-2012, 03:05 PM
1982 928 us
dang huhhah huh ha (out of breath) ran to his garage and uhh ohh no pcar in there either, someones holdin out on pics. lol
1982 Porsche 928 us
Old 10-04-2012, 03:08 PM
dont know the rouls sorry,it will be better
Old 10-04-2012, 03:19 PM
Pete R's Avatar
Don't worry, pics aren't a rule...some guys just really need car porn. All those Euro CIS components will be almost impossible to find new. At least here in the US. What is your problem anyhow? Those are all "warm up" components and should turn off when warm.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 10-04-2012, 06:49 PM
black smoke when warm engine little blue smoke to,it is on hard acceleration.how does the car like foreigns ignitions cables
Old 10-06-2012, 01:57 PM
Network Native
Danglerb's Avatar
Use of parts other than original, not good, Beru is the best way to go for spark plug wires. Several 928 vendors in the USA sell an "econo" kit, with just the wires and you reuse the ends you have, buying new ends as needed.
Black smoke usually means fuel to air ratio has too much fuel.
Blue smoke usually means oil is getting into the intake (not unusual, but needs fixing).
Best think would be to get together with a local 928 owner and have him look it over with you.
Old 10-07-2012, 12:54 AM
