Wally - Kuwait
Lifting Motor for Motor Mount Install
Just got my car back from Dealer getting motor and trans maintenance brought up to date after many years of neglect. I have motor mounts to put in place and cannot find an article I saw about lifting the engine using an eye bolt and a 4x4 across the engine compartment. Does anyone remember seeing that article and where I can find it? So far this low mileage Euro 928 S is consuming more dollars than expected, but it now runs correctly, the automatic shifts as designed and the radiator cools, all things it didn't do when I first got it. Around every corner there surfaces a new challenge, warning lights, windows that don't open and the like. Glad I am not attempting to use it as transportation. Would certainly appreciate a response if someone remembers the article. Thanks
Wally Geiger
86 928 S Euro
Kuwait
Old 11-21-2012, 09:41 AM
harborman's Avatar
Check Rennlist, I think I saw it there.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 11-21-2012, 10:19 AM
1978 928 - 9288200072
Is this the one you mean?
Motor Mount
Rick
1978 928 - 5 speed - no sunroof - Copper Brown Metallic - Cork Interior
Old 11-21-2012, 10:24 AM
harborman's Avatar
Motor Mount
Rick
Check the various sites. A number of posts around on this subject.
1986 928S
32 valve engine
Old 11-21-2012, 12:33 PM
Porsche newbie
Niles's Avatar
Here's the one I used: http://www.dwaynesgarage.norcal928.org/MotorMounts.htm
87 928 S4 Exported for Japan
Old 11-22-2012, 01:11 AM
Kyle C
I followed Dwayne's setup too.
You can make your own very easily. Just measure carefully before you cut anything. Then once you have one cross-beam assembled, place it over the engine and push down hard so you make an imprint of the bolts along the fenders on the bottom, then drill holes here so the cross-beam will sit flat and won't slide around.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 11-22-2012, 07:33 AM
Wally - Kuwait
That is the one I saw, thanks for the information from all, I'll get started on that project this weekend.
Wally Geiger
86 928 s Euro
Old 11-22-2012, 11:05 AM
