Wipers stopped working?
'86 928, no wipers, checked connector under cowling and cleaned...still nothing - nada, the washer motor comes on when you pull the stalk back, but nothing else - any common gremlins that I should check first? thanks, frank
1970 911 T 1986 928 S 2007 Mazda 6 2005 Toyota Sienna 1986 GradAll Excavator |
Petie3rd
check the fuses after that you should pull the motor out and take it apart and clean it,
its prolly rusted inside then fit a cowl cover, Jerry Feather makes new cowl covers
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
After you check the fuses, check to make sure that the arms from the motor to the wipers move freely. It could be that they have not been used in a while and merely require some lubricant and a little time to run after being freed up.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
couldn't find a fuse in the passenger footwell and I have a fuse diagram - there is a relay there, which I pulled and reset....where do they hide the fuse?
Never Mind...found it #5
